Eicca
- Joined
- Aug 3, 2019
- Messages
- 108
Obviously one can measure actual current, if it's possible to get the leads in all the right places.
But will measuring impedance also give hints as to how much (if any) parasitic draw there might be?
I tested the tail cap of my Warrior X Pro and got infinite impedance without pressing the button, and then two different readings depending on how far the button was pressed, due to its gas pedal UI.
Can the same trick be used to measure across the contacts inside the tube, since both positive and negative are at the head thanks to the strange proprietary 21700?
