Determining Lumen Output with Reflector
SmoothInnovator
I am building a light fixture using an LED rated at 100 lumens. I am applying a narrow reflector that indicates it will multiply the lumen by 52. Therefore I would assume the output after applying my reflector is now 5,200 lumens. I realize that I am not increasing the source lumen, but rather focusing it.
Would I be correct in stating that the total lumen output of my fixture is 5,200 lumens?
I am new at this and trying to learn, thank you in advance for your feedback.
No, a more accurate number would be around 60-90 lumens depending on losses from the reflector. Lumens cannot be increased from the bare emitter value, intensity can, and that is measured in candlepower.
Lumens never go up, only down. Depending on the reflector, you will be getting 60-80 lumens OTF. You are confusing Lux and lumens. Lumens is a measure of total output, lux is a measure of intensity (or throw).
