Al Combs
- Joined
- Jul 2, 2007
- Messages
- 872
What you describe as "other problem" is a fair description of parallax.Parallax has nothing to do with our problems here.
The other problem with doing it on the top so that it works for a reflector is that creating a reflector that close to the die means that in order for the silvered part to not block even part of the die from the reflector it would have to be so small as to not even matter if it was even possible at all(would depend on the reflector).
Well technically a 50% increase was what I said. That's the equivalent of a 33% loss. Osram lists in their pdf doc's the Ostar LE W E3B with the silicon dome as having an optical efficiency of 50 lm/W at 350 mA vs the Ostar LE W E3A that has an optical efficiency of 36 lm/W at 350 mA. That's an efficiency increase of 39% by adding the dome.I also have not seen anything approaching a 50% loss from removing a dome. Ever.
The top bin (WX) of the Luminus CBM-360 is 4,300 to 5,100 lumens @ 6.3 amps. The CBM-360 is output binned at full power. The CSM-360 WV bin is rated at 3,600 4,300 lumens @ 3.15 amps. On page 9 of the CSM-360 specs is a graph called, "Relative Luminous Flux vs. Forward Current". From that I extrapolated by pixel couting a 193.6% increase from 3.15 to 6.3 amps or 6,969.6 to 8324.8 lumens. That's an increase of 62% on the low side of the range vs 63% on the high side. The CBT-90 is binned at 9.0 amps and shows a ratio increase of 1.34 at 13.5 amps. The top (WR) bin is 1,750 to 2,100 lumens for an adjusted 13.5 amp output of 2,345 to 2,814 lumens. The CST-90 has the same top bin as the SST-90, namely the WN that is 1,000 to 1,200 lumens but at 3.15 amps. It's 13.5 amp multiplier is 340.8% for a total output of 3,408 to 4089.6 lumens. That's an output increase of 45%.
Here is a picture you posted of an SST with and without the Wavien reflector. You commented on the "warming of the color". I think it's a reasonable inference that if a secondary fluorescence from the royal blue peak causes a color shift to the warm, the only way two LED's, both with and without a dome, could have the same color is by using a different phosphor. That's just an educated guess on my part. If you have inside information from the LED manufacturers that allows you to say that's not so, I'd love to hear it.They do not change the phosphor based on whether it is domed or not.
I don't think it's off track at all. Newbie correctly pointed out the test would have been more accurate if a single XR-E had its dome removed. But jtr1962's test results indicate a 30% increase in output for the normal XR-E over the XR-E with no dome. If you say that's nothing but internal reflection. I both disagree and ask that you explain that statement. Is it based on something other than your best guess? The CSM-360 being 60% brighter than the CBM-360 has to be due to something other than internal reflections.You are really getting off track here. The loss in lumens from removing the dome is due to an increase in internal reflection.
And that is just your guess. Which as I said I respectfully disagree with. For the sake of people who read these posts and just assume an unchallenged rebuttal is an admission of error.You might possibly see some increase with an experiment like this but I wouldn't expect it to be much at all.
Finally I have some personal experience of my own. In a failed experiment on two DSVNI P7's I bought from PhotonFanatic, removing the dome on one made it's output much dimmer than its twin(?) brother. The hotspot was much smaller but overall output when the reflector housing was removed from the MagLites I had them in, removed that advantage. It was both much dimmer and of a different color than its twin, after the removal of the dome.
