hi, im trying to reduce the voltage of a li-ion cell to replace 2 AAA bats.
as i look around, ive found that some batteries use a diode to reduce from 3.6v/3.7v nominal voltage to 3.0v (with maximun voltage around 3.6v)
as i live in a city far away from big cities, my only shop from electronics is dealextreme
my first idea, was using a 10440 li-ion in one "slot" of AAA battery, and a dummy AAA with the diode in the other.
BUT, direct measutring the voltage with a "simple" (diode removed from small AC>DC transformer) the diode, read 3.8v. after consuming about 30ma, it fell to 3.5v (my device will use about 35mAh)
so, my questions:
1- its normal the voltage be higher when there nothing consuming power from it? (only batt and diode)
2 - consuming more ma, the voltage should drop?
3 - i was thinking in buying a "Soshine 3.0V CR123A" battery, and use the diode found on this battery (does the same as i want)
4 - the diode from Soshine battery will have a better "stable" output, or all of them have this variation depending of the mAh consumed?
my device can have MAXIMUM 3.6v input. diodes reduce about 0.7v right? this is a constant reduction?
tnks for patience. :thumbsup:
so, my questions:
