DIY spectrometer
ON_
Hello everyone,
I would like to be able to compare the color output of several light sources (mainly LEDs) but an off-the-shelf spectrophotometer is (for now) out of the question due to its price.
So the project is to build something that would have a similar result but with a lower cost.
The plan is to use a slit and a diffraction grating, and then to focus the resulting spectre onto a CCD sensor. The basic idea is to use a webcam or a digital camera and then to transform the "jpg" image into a spreadsheed with values for each pixel. The wavelength calibrations and the intensity calibrations can be done by comparing to a known source (the sun for example).
My problem lies in two areas:
1. I am looking for a simple way to transform a jpg file into a spredsheed which can be used by a software like Radiant Imaging's "Color Calculator"
2. Instead of using my digital camera (which I still need for its main purpose - taking photos), or a webcam (sensor might be too small) I thought of using the CCD sensor from an office scanner. I haven't found any way of controlling that sensor without the motor and light that are included in a scanner
so here are my questions: Has anyone here any thoughts about all this? any experience in the CCD-part, or in the picture conversion part?
Thank you in advance
Oliver
Enough experience with CCDs, spectrometers and the like that I could never justify the time it would take to build my own. A fun project perhaps, but so many issues to doing it right.
Semiman
HAving seen numerous people attempt to do spectroscopy of the sun using several thousands of dollars worth of CCD camera, and fail to get good readings, all I can say is it's a lot harder than you imagine. :(
The best results were apparently obtained with a monochrome CCD.
My personal opinion of what you're trying to do is that you'd probably find it easier and more accurate to get the manufacturers data on the bin etc. of the LED than to try and determine that data yourself.
If you succeed then I would be extremely interested, as would quite a few others at the observatory, as we would like to get spectroscopy working with our CCD cameras!
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2306
$2,000 for a spectrometer. I know it may seem like a lot of money, but what is your time worth?
From a principle standpoint, it is not difficult:
- diffraction grating or prism
- some sort of CCD -- generally a rectangular one and definitely monochrome
- Interface hardware
- software
- precision optical alignment
- more software
It would be a fun project... just not easy and I would guess ultimate not that cheap.
Semiman
I know nothing about building a spectrometer, but to answer your first question, i would try to get the output format to bitmap, then read it into Matlab and process whatever you need. You can then either write out to a tab delineated file or write directly to an excel format using xlswrite.
Hello everyone,
Oliver
try this:
https://spectralworkbench.org
and
http://store.publiclab.org/products/desktop-spectrometry-kit-3-0
If you have enough skills in electronics, you can built your own with ease, You will only need high quality prism and precision movement for it. I have built such one and it works just fine. Only drawback is, it can'be used for measuring constantly changing light - it needs about 2 seconds to sweep whole visible spectrum.
