Hi.
I want to add a relay system in my motorcycle for the headlamps the way that Daniel Stern explained in his website. I already measured my instalation and I have a 2v voltage drop in both low and high beams, so I need it.
I was researching about relays. I remember that in school we used a diode in anti-parallel with the coil of the relay, to protect the electronic circuit from electrostatic discharge (mainly transistors and chips), like this:
Hotlinked Image
Daniel doesn't say anything about this in his website. I wonder if I might have something damaged if I don't use a diode.
I have searched for the wiring diagram of other motorcycle models. For example the Honda NSR 250 MC21 does have a stock relay but it doesn't seem to use a diode: http://tyga-performance.com/images/00psm/02tpfitman/08fitmantuning/20mc21wired.jpg
The MC28, a newer model, do use diodes. If I understand the diagram correctly, it is only used in the "head light relay" and not the "high beam relay". I can't figure the exact way it is connected:
http://tyga-performance.com/images/00psm/02tpfitman/08fitmantuning/21mc28wired.jpg
So, what do you think? Are diodes needed for relays in this application? Do I have to use a resistor in series with the coil too?
Edit: By the way, what kind of relay should I buy? My bike is 12v. I guess I will use a relay that is commonly used in cars.
Hotlinked Image
