Just got mine today:
http://www.dorcy.com/products.aspx?p=414269
http://www.brightguy.com/products/Dorcy_K2_414269_Luxeon_LED_Flashlight.php
First impression was, wow, this light is bright! As should be expected since it uses 6 AAA and is definitely not a penlight. Almost the size of a 2D Maglite, only thinner (sexier mid section curve).
Two light settings, high and low. Low's brightness not much lower than high. Researched a bit but found no mention of run times. The only issue I have is the optics are not very good, has two spill rings around a bright central spot. Bright central spot is not a perfect circle.
I am generally happy with it. Cheap, very bright light that uses cheap batteries.
$39.99+ from Target.
