I wish I could tell you more. I have not looked into the situation, but, I just wanted to post and give you heads up that there appears to be a problem with Downboys specifically at higher voltages like some of the posts that have come up recently.
I suspect the inductor is too low causing trouble for the IC to handle the faster swing through the inductor.
I'm not sure and will post here when I get more information.
Until then, please test any Downboys in all you configurations before potting. Most specifically 3X123 and higher voltage configuration should be tested thoroughly before installation to weed any suspect converter boards.
Please post here any observations you have and hopefully I will be able to nail down the specifics of what is happening with the converter boards.
Thanks,
Wayne
Thanks,
Wayne
