GreyShark
- Joined
- Dec 21, 2008
- Messages
- 359
I have no ability to manufacture batteries so I'm just sort of throwing this idea out there in the hopes that it somehow someday develops into a real product.
Lately I've been intrigued by the possibilities of the 1166 incan bulb in FM's D26 G4 Sunlight module. It has great power, great color and decent runtime due to a relatively modest draw all in a light that can be worn in a pocket. Right now I'm driving it off of 3x of AW's 16340 IMR's in a SureFire host. It works great but runtime is under 15 minutes. I really want closer to half an hour to be a practical replacement for my EDC M60. I looked into the possibility of trying to run the bulb on 4x CR123 primaries but after considering the voltage drop from really flogging cells it just didn't look like I'd get much of an improvement in runtime for the greater length. I then considered 3x 18500 in a new host but while the runtime would be fine the light itself would now be four and a half cells long, quite a bit more than my favored 3 cell form factor.
After doing some research I discovered there is an 18350 Li-Ion but it's unprotected and after the draw of around 2 amps is applied I'm not sure how the voltage or capacity would hold up. During my research I read that nearly 5mm of space are taken up by the vent/PTC. It then occurred to me that a safe chemistry IMR cell could handle high discharge rates, wouldn't need a protection circuit and may not need the vent/PTC and thereby regain some of that space to offset losses in power density. Who knows, you might even be able to sneak in an extra mm into the length and still get 3x 18360's into a 2x 18500 host. It would probably be one stompy little cell.
