Strangerous
- Joined
- May 6, 2008
- Messages
- 5
What "driver" do you good folks suggest for my very first 2D Maglite modification? I will be installing a sleeve in the 2Dmaglite to accept Rechargeable 1000mah CR123A batteries, as I want this maglite to utilize the same battery as my Fenix P3D Q5... I'm just looking for something that will get me as close to the 900 lumens as possible.
So far my "parts" are as follows:
Aspherical lens for D-sized Maglite
SSC P7 C-Bin LED w/ star
PVC pipe for custom insert for battery
I know that the 3.6V~3.7V voltage input is what the said LED is rated for, so will I:
Be able to direct drive this LED with 2 rechargeable CR123A's in parallel and revieve optimal performance?
Utilize a single CR123A direct drive, get optimal performance, and save the weight of the extra battery?
Impliment a "Driver" to get the desired "Balls to the Walls" performance?
Any and all help is greatly appreciated.
