entoptics
- Joined
- Oct 1, 2009
- Messages
- 388
Spent a couple hours reading and searching, but now only know just enough to ask for direction. The reason I'm asking here instead of automotive lighting, is because my idea was to use flashlight parts hard wired to the bikes electrical system, and mounted in simple mounts. I figured you flashlight legoers would know what parts to suggest.
My front fender on my Suzuki DR350SE shadows the OEM headlight badly leaving a close in blind spot, so my goal is to provide a 10 meter semi-circle of light on the ground from the handle bars forward for both street and offroad, and perhaps something that could be used offroad to light further ahead, but turned off for public roads to avoid dazzling other drivers.
For instance a couple of cheap DX "clone heads" that could be sealed with a cheap tailcap and/or body (drilled for a grommetted hole for wiring). Then attach the heads with some sort of bicycle mount or similar.
General Requirements
1) "Cheap" (~$50 or less total) and "Easy". I'm handy enough, enjoy tinkering, and have access to good tools, but would have to pay for machining or welding.
2) Durable and easily fixable (rain/splash proof, and vibration/shock resistant). By no means SureFire tough, but it has to be able to stand bumps and splatters (MiniMag tough?).
3) Frame/Bar/Fork mounted will depend on the setup, but regardless, mounts must be moderately adjustable without much trouble. For example a 90° tilt/swivel cone with no more hassle than wing nuts would be fine.
4) Tint, CRI, etc aren't that important. As long as it won't distract other drivers or turn the rocky path purple, I'm OK. Neutral or Cool White is peachy.
Specific Requirments
1) Wired into 12 volt DC, no more than 10 watts and a few amps. (DR350 has a wimpy electrical system without much left over for "accessories" so efficiency is important too). I can sort out the wiring myself once I have appropriate parts in hand. I could probably manage a way around heads that couldn't handle 12 volts but I'd prefer not to test my electrical engineering skills.
2) ~200 very floody lumens x 2-3 mounts for ~400-600 total lumens. I wouldn't complain if I could go brighter or had a way to use multimodes. Dim for street, bright for offroad?
Any suggestions, or am I hoping for something that doesn't exist? I saw these "drop ins" in another old bike light post, and wondered if there's whole heads for sale that are as good or better for a reasonable price. A bare reflector ain't gonna cut it...
