Mr Happy
Here is what the CEF21 looks like inside. This is the Duracell Power Gauge charger (Indicator Charger in Europe).
Top view:
Upper left is the mains power supply. Transformer TNY266B brings low voltage power over to the rest of the circuitry. Lower left there are four parallel power supply channels using four coils (two hidden under the metal shield). These supply 5 V DC to the USB power output lower left when they are not being used to charge batteries. The white socket lower center is where the cable from the LED bar graph display plugs in. Lower right would appear to be a test connector.
Bottom view:
Erm...
This ain't no simple charger.
I've made these pictures as large as forum guidelines allow. I have higher resolution versions I could link to.
The square chip upper right is an ATMEGA. There is some measure of intelligent control going on in this charger.
The four big resistors seem to be connected between the AAA and AA contacts of each channel. If I read the color code correctly, it is orange-black-silver-red making them 0R3, 2% tolerance.
My goal is to modify the charger so that AAA cells get charged with the same 400 mA that AA cells get. As manufactured, the charger uses 175 mA to charge AAA cells and it seems to be unreliable at terminating. I think it would terminate better at 400 mA.
Edit: Please see post #50 below for details of how to make the modification.
Top view:
Bottom view:
Erm...
