I wanted a high-output UV LED light, but everything I find that uses the high output 1W+ UV LED's are very expensive like an Aleph head etc. And I'd also need a body to hold it. Waaaay out of my price range. I noticed this UV LED from DX http://www.dealextreme.com/details.dx/sku.4334ED for only $7+ change. And immediately thought how easily my Dorcy comes apart, and how easy it is to access the star in it.
It was my first "high output LED" from a few years back when I learned what a Luxeon was, and where flashlights were going, and first became a CPF'er. However, it's pretty ho-hum compared to most lights, even lots of Chinese cheapies out there now for just a few bucks.
I've got a 5 LED 5mm UV eBay special, but I'm disappointed with the output, and the rubber boot covering the switch failed and ripped off. I don't mind that this LED from DX is kind of high into the visible violet end (It lists as 395 ~ 410nm), as it's just a "screwing around UV", I don't have any real specific application for it, just poking about to see what will fluoresce, and charging GITD materials etc. I'm not scorpion hunting or anything.
So here are my questions. I've tried to search and read tons of threads, so I hope none are too repetitive:
- Will there be a problem with the Dorcy's driver circuit for a 1W Luxeon running this UV?
- What are the pitfalls of trying to use the Luxeon star heatsink with this Cree? Just solder it on, nicly centered, with the right polarity?
- Is there a better, easier (yet still inexpensive) host for this Cree I should be looking at instead?
- Or should I get this kit: http://www.dealextreme.com/details.dx/sku.3257 some arctic silver and stick it in some host that it would fit and would drive it at the 3-4 volts 350-500mA correctly?
If you can't tell, I'm about at the edge of my ability envelope here…
If there's a decent 1W UV from some reputable vendor for under $30, I'd go buy it instead and not cannibalize anything.
