Martin,
Your site
http://www.pilom.com/BicycleElectronics/DynamoCircuits.htm has been a real source of inspiration to me since I discovered it back in May 2005.:thumbsup:
Since then I have been playing with these voltage-doubling and series-capacitor concepts and circuits for a bike lighting system.
One interesting thing about the switched bridge-rectifier/voltage-doubler method of load matching is that the load impedance presented to the dynamo in voltage-doubler mode is half the actual load impedance. Therefore, if an odd number of LEDs is chosen the dynamo will "see" a non-integer number of LEDs' worth of load impedance. For a load of three white LEDs the 1.5 LEDs' worth of load impedance apparent to the dynamo in voltage-doubler mode seems to be a good compromise for low-speed running: somewhere between one LED which lights at a very low speed but the total amount of light is small and two LEDs which provide more total light output but don't illuminate sufficiently until a much higher minimum speed.
Another advantage of this method of load matching is that, as you said, the string of LEDs is left intact, allowing it to be used as a rough shunt-mode voltage regulator for other circuits, like a tail light and a switch-mode DC-DC converter for charging a parking-light super-capacitor.
Some time ago, the first voltage doubler I tried was the "Manual Switching between Voltage Doubler and Bridge Rectifier". This worked well with very low ripple. Next I tried the power stage of the "Automatic Switching between Voltage Doubler and Bridge Rectifier" circuit (still manually switching the gate of the MOSFET), but was immediately disappointed with the large amount of ripple (flicker) that this circuit caused in voltage-doubler mode with an old Miller two-pole bottle dynamo that I was using for experimentation. I realized it would be even worse with a hub dynamo, which you have found too. Aside from the use of a semiconductor switching element, something was quite different about the second circuit to cause so much ripple, but what?:thinking:
Further analysis of the circuit showed that it is not a modified Greinacher voltage doubler as stated in the text, but is actually a
half-wave or Villard voltage doubler. This explains the increased ripple in voltage-doubler mode. Of course, it is a full-wave rectifier in bridge-rectifier mode, but the ripple frequency halves when it switches to voltage-doubler mode, whereas the "Manual Switching between Voltage Doubler and Bridge Rectifier" circuit
is a full-wave or Greinacher voltage doubler, so the ripple frequency remains the same in both modes.
I appreciate that the half-wave voltage doubler configuration simplified the implementation of a MOSFET switching configuration. Even if half-wave voltage doubling would not produce objectionable flicker with an eight-pole bottle dynamo, the purist in me wanted to find a full-wave semiconductor-switched configuration. The Greinacher voltage doubler intrinsically has very low ripple and is better, especially for a hub dynamo.
One of my attempts at designing an implementation of the full-wave voltage doubler circuit with MOSFET switches resulted in a dual-MOSFET power stage design basically the same as your full-wave voltage doubler power stage presented in the last schematic of Posting 33 in this thread
http://candlepowerforums.com/vb/showpost.php?p=2144129&postcount=33 except with only the two capacitors connected between each MOSFET's source and one of the rectifier bridge's AC input terminals. I hadn't thought of your cunning scheme of the two additional capacitors connected to one of the dynamo's AC output terminals in order to tune the bridge-rectifier mode. That's a very clever way to avoid having to use a non-polarized capacitor.
However, one cautionary thing struck me about this configuration with complementary MOSFETs at the ends of the voltage-doubling capacitor string: On analysis it seems to me that when operating in bridge-rectifier mode each capacitor in the voltage-doubling string will be charged via its MOSFET's intrinsic diode to approximately the forward voltage of the LED string. So, the combined voltage of both capacitors in series will be double that. When the MOSFETs are turned on to go from bridge-rectifier to voltage-doubler mode, this voltage will suddenly be connected to the main DC output rails. To prevent a high current spike going through the LEDs the filtering capacitor across the LED string will therefore have to be many orders of magnitude larger in capacitance than the voltage-doubling capacitors or LED damage might result. I haven't yet fully analyzed how much of an issue this current surge is, but I think it warrants consideration.
Because of reservations about this, I came up with an alternative configuration. This simply replaces the manual switch in the "Manual Switching between Voltage Doubler and Bridge Rectifier" circuit, which doesn't suffer from this current-surge problem, with a MOSFET switch. Of course, this switch must handle AC, so this necessitates an AC MOSFET switch, which is effectively two like-polarity MOSFETs in series, back-to-back. However, both main terminals of the switch are then no longer referred to either DC supply rail (they are floating), so applying the correct gate voltages with respect to the source-terminal voltages is complicated.
A simple method I devised to simplify the drive requirements involves using either a photocoupled MOSFET AC switch, e.g. PVG612AS or a pair of discrete series-connected back-to-back N-channel MOSFETs driven by a photovoltaic isolator (PVI), e.g. PVI5050N or PVI5080N. The LED in these packages does require 5-10 mA and the ICs aren't all that cheap, but the advantage is that the MOSFETs can be fully floating and still get a reliable gate drive voltage. This method would also make it easy to directly implement an automatic-control version of the Quadrupler/Doubler/Bridge-Rectifier circuit with no gate-drive hassles. If using discrete MOSFETs, a dual PVI package like the PVI1050N could be used to reduce component count.
I have yet to actually try this AC MOSFET switch version of the full-wave Greinacher voltage doubler, but I hope to shortly.
Cheers,
John.
