E10 to Flange adaptor (DIY)
Katherine Alicia
Central UK.
This may be of use to some of you, today I made an adaptor to fit flashlights that use Flange bulbs so they can take E10 MES bulbs as well!
I used a simple E10 bulb holder that I took the solder tabs off, and soldered on a copper ring around the neck using some 1mm copper wire that I shaped around a 10mm dowel and it works perfectly! :-D
(hopefully I`v managed to get this picture thing right)
hcFQ9N8
4NRpHZ1
