E1e-LS - a few questions for those wanting this mod
lambda
Iowa
After much tribulation, the bezel finally came off. Luxeon & lens went in, here's what you get:
Here ya go, E1e-LS !
Lambda
hotfoot
Can you say, \"Durian\"?
WOW!
Kevin, how much are *THOSE* selling for?
I presume there's the same Illuminator/IllPill magic in that E1e head?
I hope to find a few of 'em on your website sometime soon...
vcal
San Gabriel Valley
Isn't the reg. E1-e supposed to be putting out about 15-18 lumens? Since that LS is rated about the same, why does the LS look so strong? Or is that running the new Lambertian LS?
-I presume you're running that mod on the standard Li cell-with direct drive. Am I right?
Inquiring minds want to know..
bucken
Indiana
WOW! That's what I've been waiting for. Will you have any for sale? How'd you get the bezel open? How'd you make the connections? And on and on he goes... Yes, inquiring minds want to know!
-bucken-
lambda
Iowa
The E1e-LS is using the Illuminator circuit to drive the Luxeon nice and bright.
Direct drive on 3V isn't bright enough to go through all that work! Yes, the bezel comes off, but only after certain Gods have been prayed to, and the chicken bones shaken just right.......
This mod was done at the request of STARLIGHT, who urged me to the point of no return with the little E1e. This will be a one way ticket to LS, as some machining of the head assembly is required to make the lens fit.
Just amazing that such a little flashlight can make so much light.
Darell
LOCO is more like it.
While you're praying to your gods, we're all holding hands and chanting "Kevin!, Kevin!, Kevin!"
Finally. I HOLA for the E1.
Fantastic! Now, what's the runtime on that little guy?
Starlight
Florida
We have known all along that Kevin is a genius, but this is unique. He has out-fired Surefire and out-arced Arc. He has improved on the mod that several others tried with an Arc LS head on an E1e. It is brighter, and fully regulated. Kevin, you da man!
lambda
Iowa
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Starlight:
We have known all along that Kevin is a genius, but this is unique. He has out-fired Surefire and out-arced Arc. He has improved on the mod that several others tried with an Arc LS head on an E1e. It is brighter, and fully regulated. Kevin, you da man!<HR></BLOCKQUOTE>
I don't know about that, but what would everyone prefer?
Brighter light with 30-45 min run time, or Illuminator brightness for (hopefully) the same 2+ hours?
Have to do run time test tomorrow, but which circuit????
Starlight
Florida
Don't be modest. You know the saying about not hiding your light under a bushel. I would prefer the brighter light, but only if it is regulated. Batteries are cheap.
Darell
I like the 2hrs... but how do you get the same runtime out of fewer miliamp-hours?
Starlight - "fully regulated?" I don't think so. Many people seem to confuse semi-regulated with fully regulated. The genius part I agree with, however.
McGizmo
Maui
Way Cool Lambda!
Any comments on the water resistance after your mod? I assume the pyrex lens is still in place?
How about more pictures :)
hotfoot
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by lambda:
<HR></BLOCKQUOTE>
Lambda, Brighter light! Brighter light! If I want runtime, I'll tote along a LW3000 or something. The only thing that would beat your E1e-LS for light density is a E1e-LS Hydra!
lambda
Iowa
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by McGizmo:
Way Cool Lambda!
<HR></BLOCKQUOTE>
Would be the same as the original, yes, pyrex lens and all, nothing is changed as far as the basic E1e, all changes are internal......
lambda
Iowa
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by darell:
[QB]I like the 2hrs... but how do you get the same runtime out of fewer miliamp-hours?
QB]<HR></BLOCKQUOTE>
I can't !
I'm just guessing at mah capacity for cr123, I don't even know what it is, but everyone is gun-ho about liths, I figured 1CR=2AA ?
Help me out here what's 2AA equal to in mah to 1CR123?
I've been too busy lately being Mr assembly line, that I've not had much time to be Lambda making new stuff and keeping track of battery densities vs ground drift and angular spin.
Take nothing I say or do as fact, I've been infected with some kind of photonic bug that I just can't shake............
Darell
Kevin -
Stick this thing down in the modified lights forum... I keep losing it up here!
If I remember correctly, AA Alks do about 2000 mAh while an SF 123 does 1300. So, if I'm anywhere near right, your Illuminator is playing around with about 3x as many of those little mAh's.
D
**DONOTDELETE**
Guest
As the world gets smaller and smaller, so do the Lambdas, I see...nice mod!
lambda
Iowa
[QB]Kevin -
Fine by me.........Empath?
lemlux
San Diego
Lambda:
CR123 is typically rated between 1300 mAh or 1400 mAh. At 300 mA One CR123 probably has more Watt hours capacity than 1 @ Alkaline AA and less than 2 alkaline AA's.
brightnorm
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by lemlux:
Lambda:
<HR></BLOCKQUOTE>
An example of this relationship that I have experienced is the difference between the UKE Mini Q40 (4AA) and the UKE 2L (2x123). Using the identical lamp, The 4AA consistantly outruns the 2L.
Lambda:
...But what would everyone prefer...brighter..or longer...?
Lambda, Brightness without extended runtime is of little use in an unexpected situation of unknown duration. A primary reason we all EDC lights is to be prepared for the unexpected. That's why I prefer a relatively long-burning mod. Besides, if it's a Lambda light we know it will be bright anyway.
I would love to get one of your mods but my timing always seems bad. Which of your creations is most likely to be available to Flashaholics in the forseeable future, and how and when can we preorder?
Brightnorm
BuddTX
Houston, TX
<HR></BLOCKQUOTE>
Heck, If I am going to spend the $$$ for a SureFire MOD, that is going to cost some bucks! Not saying that it is not worth it, just saying that it will be expensive.
SO,
What I might suggest, is an E2e mod, with a longer run time AND a brighter light.
I would go for that in a second!
The E1e is nice, and I would vote for brighter, with a shorter run time, as I could always throw another 123 in my pocket.
But, given a choice, I would rather have both a brighter light, and a longer run time, with a E2e. While bigger than a E1e, it is not soo much bigger that size would become a problem. and using lithium batteries (your only choice), weight would not be an issue either.
