E2 Lithium replacing alky D's?
Buck91
USA
I was just thinking, considering the fact the energizer lithiums are supposed to be 2000-3000 mAh, depending on application, if I were to run three sets of two parallel AA's in my mag, wouldn't I be looking at similar capacity to standard D's with much better shelf life and better thermal stability (i.e. winter in the car)?
I'm looking at these adapters, BTW...
yup 2 or 3 perfectally connected in parellel would be great for applications like that.
the problem is the lack of very good quality 2-3 To D adapters, which could make doing that not just a bad idea but even could split a cell or soemthing.
BECAUSE
You cant charge a lithium primary cell, and if the connections suck that COULD happen, its not likly and its not likly to cause huge problems, it just could.
and the shoslime adapter is a perfect example of the usual trash battery holders and adapters we get :-(.
there are AA to D battery adapters made at the forums here that dont have the connection issues. problem is they are usually series, and can be rewired for parellel easily, and they arent cheap.
how it happens is something like this:
one cell is not connected as well as the other, that other cell is getting most of the load of the light, and it discharges faster than the one poorly connected. then you take off the load (turn off the light) and the battery of the higher state, tries to charge the battery of the lower state, and lith primaries dont want to be charged.
As Long As the parellel items would stay well connected, everything would go fine.
an alternative, although not cheap by any means, is D sized Lithium primaries, they handle only so much load, and cost ,, some 1/2 million dollers each :)
there is a post about them if you search for "Lithium D" cells, its NOT the computer ones, its a higher discharge one.
I know alkies can cause acid leaks if they rupture, but what would the effects of a lithium primary splitting be? I'm very tempted to go this route after my d's kick the bucket this season.
a lithium primary being charged could try to vent, or fissel, or pop, a fissle could ruin your light, a pop could ruin more than that :)
using Energysers might prevent issues, beings they are tested more for that kind of thing.
but if you can get a very good connection, then you will have a very good light.
then you still want to keep your vehicle temperature reasonable, and keep it out of the sun and all
like using sunscreens when parked, leaving a slight crack of a window open when the sun could take your autos temp to 140* F and up.
