The size of the light, output, and beam of the E2DL make it very unique. I don't of any other light that compares to it.
- It isn't much bigger than it needs to be to fit everything in it, comparable to many lower output lights.
- It is up there with the brightest of single emitter LED lights.
- Its hot spot is gigantic, about twice the size of other lights.
- It has very little to no spill outside of that hot spot.
It's small and bright, and it's great if you're not concerned with anything other than what you're pointing the light at. I saw a thread, not on here, that showed the importance of side spill... having no side spill would be like having no peripheral vision and never seeing anything out of the corner of your eye. IMO, this light should not be used for law enforcement, or even going outside to inspect a noise you've heard. The beam puts it in more of a casual class of light.
I don't think there is a light out that stands next to it.
