E2DL vs SST90/6PDL
outersquare
sokali
http://i602.photobucket.com/albums/tt106/outersquare/e2dl_vs_sst90_beam.jpg
http://i602.photobucket.com/albums/tt106/outersquare/e2dl_vs_sst90_lens.jpg
http://i602.photobucket.com/albums/tt106/outersquare/e2dl_vs_sst90_body.jpg
thought someone might like to see this
i just set the camera and light on a cardboard box, i don't do this often, so the aim is not exact, but the exposure is the same 1/5s, F2.8
Thanks for taking the shots.
If both exposures are the same, then....
SST-90 is a monster! :faint:
I take it the SST90 isn't going to be a throwy light.
Is this the L4s replacement?
I'm not too sure about that. Look at the chair at far end. E2DL is supposed to be a thrower, and the chair is a tad brighter using SST-90.
That beam doesn't even look like my E2DL beam. Mine is the first batch single mode but that shouldn't mean anything.
The SST-90 is substantially brighter, but it has so much pure spill I was a little surprised at how bright the end of the alley was.
I'm just lost but it doesn't matter. I hope to buy an SST-90 soon. Or a 50, I haven't studied that thread well enough yet.
Flood or throw, it's still impressive. I can only imagine it with a deep wide reflector. Hopefully, Raptor 3 or Intimidator can answer that. :popcorn:
How fast must that thing go through batteries?
I was wondering, its a single die right? So would it need the larger reflectors like the MC-E and P7 to throw?
i don't know about battery life, i haven't had it long enough.
I had an MC-E dropin also that ran around 30 mins regulated on high, so I expect this SST90 to be even worse.
this is a single mode, direct drive, it starts getting hot the instant it is turned on. The pictures are with basically new batteries, but the output starts dropping off from peak after using it a couple times just because how quickly it eats batteries. So the output/discharge is probably like an incan.
i wonder if a TIR/optic can be made for this LED, that would be even more insane.
