This one?
See my post above.
The battery is too short. The spring on the E2HT head might be
just long enough to establish contact, the spring on the E2XTD just a bit short. In either case, the flat top INR cell (which is considerably shorter than a protected button top) is failing to compress the head and switch springs enough to maintain reliable contact. This from the malkoff website;
Description
This MDC 18650 flashlight body will allow you to power your Malkoff MDC and E-Series/Scout Heads with a single 18650 protected button top battery. Flat top batteries will need a spacer. It will NOT WORK on the new Surefire DF Series Heads. They have a larger thread pattern.
Once you are using a longer protected button-top (or a 5mm spacer with the INR flat top), let us know if you have any further difficulty.
