Maybe one can find this posted before, didn't check
For those who don't remember and for beginners.
If one want to try to calculate some around electricity here are some easy to remember formula in triangle from Ohms law
For calculate the one unknown, from two known.
V= Electrical force measured in Volt
I = Current measured in Ampere
R= Resistance measured in Ohm
./ V \
/ IxR\
From top divide with one under to find answer for 3. unknown. From under multiply on same line. Exampled V= IxR or I=V/R
To calculate to/from power
P= Power measured in Watt
../ P \
/ VxI \
Exampled VxI=P.
3V x 8A = 20Watt.
Power work-hour
If one have one known factor of time, one can calculate also work-hour.
Just put numbers in
Exampled: One know current-hour (Ampere hour) is 5Ah and Volt is 8,4V.
8,4V x 5Ah = 42Wh (42 watt hour)
Remember this triangles is easy !
btw i am no teacher and will never be, so that is said
If anyone find error in my in-hurry written lesson, post on.
i try to correct
./ V \
/ IxR\
../ P \
/ VxI \
Exampled VxI=P.
3V x 8A = 20Watt.
Power work-hour
Just put numbers in
i try to correct
