wquiles
June 25, 2009 EDIT: Eaton replaced the damaged compressor and sent me a new one (no additional cost to me) - you can see the new one here:
http://www.candlepowerforums.com/vb/showpost.php?p=2994385&postcount=44
As far as I am concerned, Eaton Compressor's customer support is EXCELLENT ;)
Will
I just took delivery of my new Eaton Compressor, and unfortunately it was not even close to perfect. I am sure Eaton will work with me to make this right, but I am not too happy at the moment.
Now, for point of reference, this is my old and very noisy compressor:
and that my friends is the tiny pump on this thing!:
the very fast 3450 RPM OEM motor (note there is no HP rating!):
Now, this is the new Eaton compressor that I just got today:
Of course, this is minor, but one of the plastic handles broke - I am not worried about this. This is the one is not broken:
this is the broken one:
One of the metal legs was bent (not quite broken). Not good, but not terrible either:
Now, the 120V AC cable was pinched at two places, and in one of those pinch places it was actually cut:
There was no security key available to open the covers either - I expected that to be sent along. I use pliers to turn the key open, and this was the only documentation/parts that I found:
Then I noted that most all of the wires were loose - it looks like no-one checked the unit before being sent. Even if the external AC wire would have been in good order, inside it was actually DANGEROUS, and with no documentation as to how to wire it properly. Right now I don't have any information as to how to even correct these wiring problems!:
The other side had the cover of the regulator loose:
and I even found extra crimp and pieces on the inside, some new, some just debris:
Now, don't get me wrong. The actual pump is very large for the air/pressure generated, and it is a V twin piston design. The motor is very large and stout-looking. The overall housing/package is awesome. It just looks like a simple quality hiccup. I am 110% sure Eaton will make this right for me ;)
Stay tuned for updates ...
Will
Will
Will
