DansGunBlog
Hi guys!
Hoping for some advice on the right EDC light to transition to from my Current FourSevens Mini ML/123.
The Mini ML/123 has been my go-to EDC light for over a year. Use it daily, from taking my pups out late eve to various "hey, can't quite see that" around the house or anywhere. Super useful light, love the output for how small it is, and how well made it is.
But I'm looking to replace it with something that best meets the following criteria (in decreasing order of importance, tho all are important to me):
- One-hand operation (clicky)
- Twice or more the OTF lumens of the Mini ML/123 for high mode
- Moonlight mode - I often need lower light than the minimum on the ML/123
- Ability to turn on in High mode directly (without further clicks)
- Ability to turn on in Moonlight mode directly (without further clicks)
- Aaaand.... small enough for EDC (that's relative of course lol - ideally not much bigger than the ML/123, but realistically max 4.5" length and max .8" or so width. Wallet is a Maxpedition Micro Pocket organizer, and ideally it will neatly fit in there as the ML/123 does now.)
After a lot of looking, I've narrowed it down to 2 EagleTac models...
1.) EagleTac D25c
- Leaning most to this one.
- Seems to have Moonlight mode where others do not.
- And I THINK it can be started in high or moonlight mode at the first click. Is that correct?
** Does anyone have both the FourSevens Mini ML/123 and the EagleTac D25c? Curious how you'd compare them... **
2.) EagleTac D25LC2
This one pushes the carry-ability factor but may still work. And no Moonlight mode. But it does have lots more output in high mode for just $15 more and not "much" more size... sigh.
3.) Sort of, not really... but since I'm considering the D25LC2, the brand new DX30LC2 is barely any larger but more powerful. Ugh... size creep. May just be too big tho.
Thoughts? other options I should be looking at?
Thanks!!
Dan
*** UPDATE 10/17:
Now looking primarily at the Olight S1 Baton and Zebralight SC62w.
1.) EagleTac D25c
2.) EagleTac D25LC2
Thanks!!
Dan
*** UPDATE 10/17:
