==================Flashlight Recommendation Checklist================
This will be mail-order or Online (location doesn't matter). Pref UK
2) Budget: An easy question, but you may change your mind after answering the rest! :)
Essentially unlimited.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I would like a light from a specialty manufacturer (Possibly limited run/Custom).
Pretty much any, but have rechargeable cells in AA, AAA, CR123.
All of these please:
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want multiple light levels. (Some lights have 5-16 light levels.)
Sounds nice, but optional
____I want a selector ring.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
____IPX7 (Waterproof to 1 meter/30min) or better
16) Storage conditions
Pocket
Pocket Clip
Currently have RA Clicky, but have to send it off for repairs.
3) Format:
4) Size:
6) Manufacturer:
Pocket Clip
