Regarding how much energy is in a gallon of gasoline... It is around
115,000 BTU.
The conversion from BTU to kWhrs is:
115,000 BTU/gallon * (1/3.414 BTUperWHr) * (1kW/1,000 W) = 33.68 kWhrs per gallon of "heat"
A reasonably efficient gasoline generator can get between 5kWhrs and 6kWhrs per gallon of gasoline.
5.5 kWhrs per gallon of elec / 33.68 kWhrs per gallon of heat = 16.3% efficient
$2.00 per gallon (swag) / 5.5kWhrs per gallon = ~$0.36 per kWhr (excluding capital cost, wear and tear, other taxes and fees)
My current Net Metering Rate (
PG&E, E7 Time of Use, note E1 is flat rate residential), but basically (because I have grid tied solar), I pay/receive:
off-peak rates; from $0.09 to $0.37 per kWhr
(more I use, more I pay)
on-peak Summer rates; from $0.30 to $0.58 per kWhr
Because I don't use a lot of power, my kWhr rate is $0.09 / $0.30 and I generally consume power at $0.09 per kWhr and I get "Credits" at $0.30 per kWhr... The credits are good during one calendar year... If I use more than my minimum $6 per month electric bill, I pay the utilty. If I generate more than I use during the year, the credit is reset back to Zero dollars.
So, It is close, based on my current (very high) California power rates--if you end up needing to burn gas to make up the power costs...
Not to mention that most long term rechargeable batteries do wear out faster the more, and deeper, you cycle them.
In theory, your car could just sit in the driveway and the electric company could wear out your $10,000+ battery without you ever driving your car.
Generally, batteries have on the order of 100's to thousands of cycles before wear-out. Whether that wear is from driving or utility cycling, it does not matter.
Of course, batteries also fail over time (years of storage), even if they are not cycled.
For the price per watt of storage, it would probably more cost efficient if the utility made purpose built storage sites (batteries, pump, compressed air, whatever)... These storage systems (other than pumped hydro) are still at the initial testing stages and all pretty much have 20-50% (or more) energy losses for charging/generating AC. And depending if you wish to store the energy for a few minutes or days-months--each offers it own advantages/disadvantages. And there is not (that I have heard of yet), a lot of these plants being rolled out at this time.
In any case, having a function to disable charging if needed (for lower cost of kWhrs), would not be difficult or expensive to implement.
-Bill
And I should add, Utility controlled switching of heavy loads, even residential (such as hot water heaters and A/C) is already available and used in many places.
