zband
I have a boom box that I am should run off of 6 d-cells. The voltage needed (on the boombox ) is 9V and 20W. I would like to run it using nimh rechargeable batteries but here is the problem- I dont want to spend the $ on them if they are not going to work.
I have 6 old duracell batteries each one shows a voltage of 1.45 V (except one - 1.32V) The voltage coming out of the pack is measuring 8.4V and the unit doesnt turn on. Is this because the total voltage is too low -or - the batteries cant make the amps?
Because if my goal is to use rechargeables then the total would come to 7.2 volts (6x1.2v), which is even lower than what my old duracells are putting out so, at least in my non-academic mind, rechargeables wont work.
Any clues, or insight would be greatly appreciated!
