Embarrassed but gonna ask anyway
BrightestBulb
I want to replace some batteries with protected cells so there is no problems. How do I tell if they are protected??? Do some manufacturers put them in as OEM??? What are the best brands of 18650 protected and where to buy? Thank you in advance.
No need to be embarrassed --
we are all friends here !
Would be VERY helpful if you could first tell us:
WHAT flashlight(s) you intend to use these cells in ?
lovecpf
_
BTW --
Orbtronic is an EXCELLENT vendor for this !
:thumbsup:
_
Before you jump to protected cells, be aware that they are significantly longer and a bit fatter than regular cells. They add all that protection over top of a regular cell, so it makes it bigger. So, make sure they'll still fit in your devices, before you buy a bunch of them. They're also significantly more expensive than regular cells.
IMO, common sense will get you far more protection than a protection circuit, but they can have their places in multi-cell configs.
Definitely good advice. Confirm your flashlights will fit the slightly larger diameter and significantly longer length.
lovecpf
_
BTW --
:thumbsup:
_
I have a Surefire M3 that I am putting a drop in LED module and it will use a 16650. Sunwayman D40 would like to change out AA to rechargeable protected. Found out both my Mankers are protected. Still don't know how to tell if a battery is protected or where to buy batteries along with the company mentioned. Have a LiitoKala 600 charger and would use non-protected if someone would give me some basic rules on how to keep them safe. Thanks!
There are a number of clues that a battery is protected.
It will have an overwrap - a second shrinkwrap layer. It will have a metal strip running up the side of the battery between the two layers of the shrink. If you can't see the strip directly, you can see and feel the slight bump where it is. It will be significantly longer than 'nominal'. One end will look funny, like there's an extra disk on the end. Like the metal strip, this will be between the layers of shrink. Often one or both ends will sound hollow if you tap on them, like it's a thin piece of metal with space behind it, because that's exactly what it is!
I use cells with safety circuits ("protected" cells) unless I have an application-specific reason not to, such as those where the typically extra length involved is a problem, etc. That is my baseline policy aside from such specific exceptions. I also ensure that all the various specifications for any cell are appropriate for my application(s) [such as max. continuous current, etc.]
The additional length, certain appearance details, etc. can often indicate that a cell is thusly equipped, although I rely on the manufacturer's / supplier's specifications as the definitive answer, as with all specifications. In the end, it is their specs that matter, not my conclusion based on observations, and if I don't trust their specs I don't buy their products in the first place. If the specs don't say it's "protected", then as far as I'm concerned, it isn't.
Yes, many flashlight manufacturers who include cells with a light do include "protected" cells in that case - in fact most / all of the reputable ones whose products I buy. Fenix, Streamlight, Surefire, and others are examples.
I buy cells from established, reputable, reliable U.S. distributors who also provide complete specs for those - which I won't name here because I don't think that's appropriate.
I've had good results with the Fenix-branded cells that they sell (also available from the various distributors referred to above), and that specifically includes 18650s, which they sell several variants of.
EDIT: BTW - In product / systems engineering where I work, users' common sense and good engineering practices for safety and reliability are not considered mutually exclusive. It is not an 'either / or' proposition. 'Both' is the preferred choice whenever possible. The human is often the least reliable element in a system, and ALL humans are prone to error. Furthermore, where safety is a critical objective, one safety measure is rarely considered adequate where two are practical. This also applies in 'high reliability' engineering, but particularly where safety is a concern.
...would use non-protected if someone would give me some basic rules on how to keep them safe. Thanks!
This may not be a comprehensive list, but I'll have a go at starting it.
Never:
1. Over charge, voltage or current.
2. Over discharge, voltage or current.
3. Exceed temperature ranges. There are separate ranges for charging, discharging, and storage.
4. Leave a cell deeply discharged for long, then try to charge it.
5. Be stupid - burning, denting, nailing, shorting, eating, etc.
Protection circuits protect against the first three (except storage temperature). The rest are up to you.
Using a proper, quality charger should protect you during charging.
One of the ways cells get over discharged is by having two or more in series that are mis-matched or imbalanced. If this happens, the weakest or least charged cell will reach full discharge, and the remainder will continue to push current through the load, and the fully discharged battery. This will over discharge it, possibly even putting a negative voltage on it. This is really dangerous. That's why many people say NEVER run unprotected cells in series. A device that operates on a single cell will usually stop working before the cell is dangerously over discharged, which is why many people feel quite safe using unprotected cells in single-cell devices. However, this may depend on you knowing the cell is discharged, and removing it from the device and charging it.
If you are really interested, go to batteryuniversity.com and be prepared to spend some time reading.
Oh, and I've been happy with batteries bought from Batteryspace.com and Liionwholesale.com. I also bought some Keeppower cells on Amazon that I think are genuine.
Thank you all very much!!! I have a lot of great info now. Will be saving this thread for reference along with Battery U!
A 16650 is a 2x123-sized cell, and would require a spacer. 3xR123 is an option, but you'd need a LED module that could take 14V.
What's the LED module?
There is an additional safety risk that "protected" cells have, which unprotected do not. If the inner shrink wrap is damaged, then the (positive) metal strip down the outside of the cell can short-circuit against the (negative) metal wall of the cell. Not good. It's important to always keep the shrink wraps in good condition. It's super-important if you use protected cells.
The protection circuit is add safety to the battery. It's not necessarily to add safety for the user.
Only cell I've ever had fail was a protected LG 18650. Don't put too much stock in protection circuits.
You will want two protected 17500 for your M3.
Duh. I forgot that 2x14500 is another option. You'd want a sleeve to keep them from rattling. I used to use 2x17500, but am not sure if they make them any more. The 14500s I just saw on Orbtronic's site were the same capacity as my old 17500s(!).
Anything that can work can and will fail - which is great for me, 'cause that's how I make a living!:)
Gotta say it's relative though - a failed cell vs the kind of potentially catastrophic failure modes a safety circuit is intended to prevent. Even I can do that math! I'm sure your dwelling has breakers in a distribution panel somewhere, and if one of those breakers fails (which they can and do), I've got 20 bucks says you don't say 'dang breaker!' and bypass it. I'm pretty sure you'd replace the bad breaker.
EDIT: Just to clarify that I agree 100% with the premise that one should NEVER, under any conditions, intentionally rely or depend 'absolutely' on any safety device or system (which I think was your point), and I wanted to amplify that. Whether it's a safety circuit on a cell, or a safety device or system on an industrial machine / system, or any other type of thing implemented as a safety function - it is always considered 'forbidden' to rely on them completely unless conditions require it and leave no other option.
True, almost any added component adds an additional failure point &/or mode, and that's no less true of 'protected' cells. A damaged lithium ion cell of any kind, however is never good. I use a lot of good grade heat shrink in industrial applications, and I find it to be very tough stuff - but anything can be damaged. I treat mine accordingly (with proper care), do a quick exam on them occasionally, and check them any time I think they might have been subjected to ANY harsh treatment - and have never had an issue with a damaged wrapper. I'm careful with mine for sure, however not everyone is so astute about such things, and I'm sure the kind of damage you're talking about does indeed happen. Carelessness and lithium cells don't mix well. In general though, protection devices have risks, but one must weigh those risks as they are not all equal.
Now I'm not picking on you here, but I've often read comments similar to your last one that generally state or imply that 'protection circuits exist to protect the battery, not the user'. I'm sorry, but I laugh every time I read such comments. We're talking about something that has some potentially horrible failure modes here - and it's in my pants pocket. Such comments imply that I'm supposed to differentiate between the wellbeing of that cell and the wellbeing of my leg and which is being protected? Sorry, but I can't do that:)
Sorry, WalkIntoTheLight, and this is very unusual between us, but I couldn't disagree more strongly.
UL and other safety certification agencies require protection circuits in most devices that use LiIon cells.
Having been through UL certification with LiIon batteries, (and pursuant to this having read the relevant UL specifications) I can say that they don't specifically require or refer to "protection circuits". However, they do require that charge and discharge currents and voltages remain within specifications for each cell given any single fault in the device, including shorts and 50% imbalance among cells. AFAIK, this can only be achieved using protection circuits, whether they are attached to and essentially part of a single loose cell or part of a larger multi-cell battery assembly.
Whatever protection mechanisms are used in your device to pass certification become required equipment. This includes manufacturer and model number of power supply, charging circuit, LiIon cell, and protection circuit.
Safety agencies generally don't care a whit if the cells are destroyed, or if the device continues to work, so long as the user is protected. So a lot of safety experts around the world must think that protection circuits are to protect the user, and I am in complete agreement.
I'm just 'bumping' a clarification edit because it involves safety, so I want to be clear.
I'm not sure a safety authority would approve of running a positive metal strip down the negatively charged can with a separation of less than 0.1mm. Those protection circuits are great for preventing over-discharge in super-cheap crappy lights, but I'm not convinced that really improve the safety of lithium-ion cells. Besides, I don't think individual cells are approved for consumer use; they're meant to be used in sealed battery packs.
That said, they may have some benefit for careless users that carry around cells in their pocket with loose change, or run the cell down way too far in a device that has no LVP. Fair enough. But for anyone that goes to the trouble of subscribing to a flashlight group and reads the battery forums, I don't think they add any safety at all. We'll all familiar enough with proper battery use and care.
The only exception I'd make is for multi-cell (in series) configs. Again, it's for the protection of the battery, so you don't ruin it by over-discharging it. Any competent user in this forum knows to check voltages before charging, so we don't need protection circuits for safety.
