I recently purchased some Sanyo Eneloop slow discharge batteries. I charged them from 60% charge on arrival up to 100% charge using and Ansmann Energy 8 Charger. It took about 2 hours and there was no overheating.
Does this charger qualify as a "Quick" charger and should not be used for Eneloop battery charging? Its PDF Manual says it is a "fast" charger. Is that the same as "Quick?"
If it is not recommended to use this kind of charger, have I already ruined the life of these batteries? How long do you think they will last now?
I notice there are some new chargers out where the user can specify the amperage of the charge in 200, 300, 500 and 700. If I purchased one of these new chargers, should I use it at only 200?
Thank you in advance for any advice.
