Eneloop charger - can it charge only one AA?
Igor Porto
Hi guys, I want to buy an Eneloop charger and a few AAs. I'd like to buy the MQR02 model, which can charge up to 4 AAs at once.
http://www.eneloop.info/products/chargers.html
But looking at the specs, it says the charge is 1,2V @ 1275mA × 2 (AA), but it doesn't say what the charge is for only one AA. There's a green LED on top of each pair, to show the charging status.
If I put only one AA, will it charge it?
Or do I need the MDU01 charger, which can charge only 2 AAs, and the spec says 1,2V @ 850mA × 1?
I don't use that much batteries, and sometimes I need to charge just one for my L1T.
Thank you.
Hello Igor,
I believe that if the output is listed as 1.2 volts, it is an independent channel charger and you can charge one cell at a time. On the other hand, if the output is listed as 2.4 volts, then you have to charge cells in pairs.
Tom
Hi guys, I want to buy an Eneloop charger and a few AAs. I'd like to buy the MQR04 model, which can charge up to 4 AAs at once.
There seems to be a discreprency -
the link you gave goes to a MQN04 -
there does not seem to be a MQR04 listed
At the link you gave -
" MQN04
• Input: 230V ± 10%, 50Hz
• Output: 2,4V, 250mA × 2 (AA)
2,4V, 120mA × 2 (AAA)
• Charge Control: Timer 16h
• Charging Time: 16 h
• Charge-Indicator: 2 LEDs "
Of course if yours is a MQR04 - then all bets are off -
perhaps you can post the specs on the back and/or the user manual?
Or you can simply put just one battery in the charger and see if the LED lights up?
- if it does, then wait a while and see if the battery has gained charge?
Edit to Add -
I did find a MQR04 charger (via a Chinese site) and Here - both say -
SAN-MQR04-ENELOOP
Charging time 10 (h)
The spec'd 10 h charging time seems to be different from the spec you gave of " 1,2V @ 1275mA × 2 (AA) " which would put the charge time closer to just under 2 hours(?).
I would not use any to them,
and would never use any charger that does not charge the individual cell
(means: the one on the left is crap, no matter waht. The other 2: who knows)
There is the MQR04 on the link, not the pic, just the specs:
MQR02
• Input: 100-240V AC, 50-60Hz
• Output: 1,2V, 565mA × 4 (AA)
1,2V, 1275mA × 2 (AA)
1,2V, 310mA × 2 (AAA)
• Charge Control: delta V
Charging Time:
- 100 minutes 2 ( AA )
- 220 minutes 4 ( AA )
- 155 minutes 2 ( AAA )
• Charge-Indicator: LED
• Size: 105 × 65 × 27,5 mm
• Weight: ca. 95g
Sorry!!! It was a typo! :ohgeez: Already fixed. Thanks for the attention.
OK so we're talking about the MQR02 -
the specs given seems to indicate only in pairs -
BUT when I did a search on "MQR02 pdf" - I found this - NC-MQH01
which seemed irrelevant -
until I opened it and found this line -
So it would appear at least from that document it can charge one battery at a time? But I cannot attest to how reliable this information is.
EDIT to ADD -
in searching for images of the MQR02 I found this page on overseas.sanyo.com
which seems to confirm it will charge one battery at a time.
BTW - the image(s) I found also from the same overseas.sanyo.com site seems to show only ONE LED indicator....
these data seem to show that the chargers (MQR03 and MQR02) can charge one, two, three, or four cells at a time.
BUT
"only" 2 places feature something that "checks" for what ever it checks
(cell charging cradle 1 and 3)
and if there are any other cells added, then they are simply hooked in in parallel to the 1st cell --> thus dividing charging current and doubling time
(cradle 1+2, 3+4)
three cells: 1+2-->255 mins + 3-->115 mins
again: I would not use them
I found a FAQ HERE that says:
Do I have to charge 4 batteries at a time in the 4-position charger, or may I charge only one?
The eneloop 4-position charger battery slots are designed in pairs. It is designed so that it may accommodate charging 2 batteries at a time - 2 in the inside positions or 2 outside positions - or 4 batteries at a time. The charger charges AA or AAA only.
The problem with that quote is which 4-position charger were they refering to? - since Sanyo/eneloop now make so many - for example the original 4-position charger was the MQN05 - could unequivocally charge 1 at a time -
whereas the next one the MQN06 could only charge in pairs -
and indeed when one Download Instruction Manual (pdf) from the products page - the 4-position charger is the MNQ06 -
so the FAQ description is accurate - for the MQN06.
Please see these -
Eneloop Costco pack, different charger
Sanyo Eneloop Battery Chargers - Spec Sheets
Costco's Eneloop Power Packs - Picturing the Difference
