This is a very interesting and practical flashlight from Energizer - that's supposed to be purpose built for preparedness/emergencies.
When I think about power outages (flashaholic dreams? ) - the lights - that's plural - should have long runtimes with adequate light - be able to throw a beam on the scene - but also an area light and have a locator light.... that's fine for multiple lights - but quite a tall order for a single light.
Well I think this Energizer Weather Ready 3 in 1 LED light manages to do those things.
Packaging (I got the photo on the left off the web)
size -
head -
This light as its name suggests has 3 functions -
regular flashlight
lantern/area light
night light/locator.
As a flashlight it does pretty well, using 2 "premium" Nichia LEDs with a simple reflector and two focussing lenses - it manages to throw quite a wide even spot of light - with some pretty patchy and strange side-spill (which was very reminicent of their 3 LED HeadLamp )
vs. sMJLED PR2 bulb in Ray-O-Vac plastic 2D
Despite the differences - they are about the same ballpark in brightness - the Ray-O-Vac 2D with sMJLED throws better because of the reflector design - the 3 in 1 has a much wider hotspot which is better for indoor usage - which is mostly what this light is about - remember in a real power outage any light is better than no light at all.
vs. Energizer LED HeadBeam - 2x Brighter
seem quite a bit brighter than the LED HeadBeam (which also uses two white "2x brighter" Nichia LEDs with two focussing lenses) but we're talking about 2-3 years on so perhaps the Nichias used in this 3 in 1 are brighter than the circa late 2005 LED HeadBeam.
Lantern mode - this uses three white LEDs housed in a white frosted tube - there is some kind of convex cone reflector toward the top which helps bounce the light out.
left - lantern mode in darkened room - exposure adjusted for the light.
right - -2 stops flash fill showing the flashlight.
NightLight/Locator Mode - this uses a single amber LED in the same area as the three white lantern LEDs -
All-in-all this is very good purpose built multi-functional light for emergencies and power outages - it has claimed very long runtime of 100 hours on the flashlight (2 LED) mode.
I inquired at Energizer.com about the runtimes on the other modes and got this reply:
"Runtime using the 3 LED's in Energizer Weather Ready 3 in 1 Flashlight (WRTWL41E) will be approximately 55 hours. The amber nightlight will run about 140 hours on a fresh set of batteries."
The light is well constructed using pretty high impact grade plastics - how so I know it's high impact? - well embrassingly during my beamshots the light fell (while On) over 4.5 feet onto concrete floor - and I was sure it was going to damaged/cracked - but not a sign of the fall.......
It is weather sealed with an O-ring on body tube where th head screws on, the single button switch is also covered.
The only aspect that might be annoying - since the light only has a single button switch (advantage - simple to use) it switches on the light in flashlight mode - then the next click switches on the lantern mode and next nightlight mode. This sounds quite simple and logical - except when using in the flashlight mode - I kept expecting the switch to turn off the light and it still catches me by surpise that the body lights up in my hand.... DoH!- obviously lantern mode !
This light was available at WalMart normally for about $13.88 -
but I found it at (I think) a closeout for $7
- now that's a bargain!!
EDIT to Add -
found on web - Video review of this light
- gives very good idea of the aspects of this light - check it out.
Index to Follow Up parts -
Stairway "beamshots" of lantern mode - Post #38
Stairway "beamshots" of lantern mode compared to ceiling bounce shots of Cree Q5 and Rebel 100 flashlights - Post #41
size -
head -
regular flashlight
lantern/area light
EDIT to Add -
