Epoxy for heatsink
JohnR66
SW Ohio
I have a 16 pin DIP stereo amplifier IC. On one side, all the pins are dedicated to heatsinking. I don't have the room to provide adequate heatsinking on the board, so I want to epoxy a copper or aluminum plate to the IC itself to augment the heatsinking. I have two part clear epoxy. I wonder if it is adequate to use? Thermal conductivity is not paramount, but keeping the heatsink put is.
Thanks
I've used JB weld to pot both drivers and LEDs to heatsinks when I was out of the Arctic Silver adhesive. I've never noticed any degraded performance. As long as you keep the amount as small as possible, I would think the clear epoxy should work. The only drawback I can think of is the different material expansion rates of the chip and the sink. It's possible the flex between the parts could eventually crack the epoxy loose.
