Fenix HP20 released !!
daf3m
A few hours ago ,the Fenix HP20 was officially released!
Cree XP-G LED (R5) with a lifespan of 50,000 hours• Uses four 1.5V AA (Ni- MH, Alkaline) batteries
• Headlamp: 70mm (Length)�m(Width)�m(Height)
Battery case: 108mm (Length) �m(Width)�m(Height)
• 260-gram weight (excluding batteries)
• Digitally regulated output - maintains constant brightness
• Separate design, evenly weight balanced, more comfortable, particularly caters to extremely freezing conditions
• Drive-by-wire biswitch, simple and fast operation
• Light head made of durable aircraft-grade aluminum, the rest made of plastic of high quality
• The metal part adopts type III hard-anodized anti-abrasive finish
• Toughened ultra-clear double glass lens with anti-reflective coating
http://www.fenixlight.com/viewnproduct.asp?id=76
:hitit:
A remote pack headlamp from Fenix? That's a welcome development. Glad to see they've stuck the flashy modes in a separate part of the UI to the normal lighting modes. I'll be interested to see how waterproof the pack and the cable glands are.....
wow!!!i´m glad fenix is experimenting with new designs.
looks incredible,any news on price, or when it will be available?
It is good that they started to rate their new models in compliance with ANSI/NEMA FL1 standard. So it is actually 230 real OTF lumens. :thumbsup:
Just need a price. I almost bought one... but I'll take better run times- the beam shots I don't know if I like the spill yet, as when I wire electrical I usually need a little more off the side.
+1 to '51lumen strobe.' This could be the start of a great option for cyclists. Always the flashy modes are full power, which with CPF lights is just too bright for a blinky for cycling. I'm very pleased with this development.
-needs a moonlight, but otherwise 6lumen is good progress.
A cotton bandanna and no hat in the winter...LOL! Well in anycase it looks great. I hope they have enough cord between the battery pack and headlamp. I wonder how that large reflector will work out?
$102.95 at 4sevens wow!!!!
I'd like to know how low the claimed temperature is tested :sssh: "caters to extremely freezing weather"
I want to know if it has the 3 minute turbo like the HP-10.
If not, this is going to hurt the budget ...
Looks nice, too bad they didn't put a neutral white xp-g in there:shakehead
Will have to stick to my Apex with a neutral XP-G and extension cable a while longer:whistle:
True, I would have preferred a neutral white XP-G R4. They are using one in the new LD40 and the specs of that are quite amazing so I hope they release a neutral white some time too.
Wow, 3.5 hours on Turbo is a big increase over the HP 10's Turbo at 2.5 hours!
Finally a headlamp with a removable battery pack from Fenix, although 260gr excluding batteries i think is a bit heavy if you want to use it for trail running. Let's hope they make a better diffuser than the one used in HP10.
