Again through the kind courtsey of 4sevens (http://Fenix-Store.com) the other much anticipated light - the Fenix L2D CE -
The head is the same as the Fenix L1D-CE - just on a 2x AA body -
Size -
I deliberately changed my normal layout and lined up the tails of the flashlights - one can see that the new L2D-CE is longer than the L2T because of the longer/bigger head. Also if one looks carefully the diameter of the L2D-CE head is wider.......
This photo should show it better -
Head -
L2D-CE Turbo vs. Fenix L2T High - both on Alkalines
the Cree XR-E in the L2D-CE clearly is brighter than the previous generation Luxeon III
L2D-CE Low vs. Fenix L2T Low - both on Alkalines
comparable.... so the L2D-CE has a usable Low level -
However I remember lots of people used to complain that the low of the L2T/L1T wasn't low enough....
(can't please everyone.... even if this level on the L2D-CE, rated at 9 lumens, is supposed to have a runtime of 55 hours!!!(but battery type not stated - 2500mAh NiMH? vs. the 22 hours of the L2T)
L2D-CE Turbo alkaline vs. P1D primary CR123A High
not surprisingly similar to the L2T High comparison....
The P1D would be a fabulous light by any account until the arrival of these Cree versions.......
vs. P1D both on primary cells - Low
again the Low levels are similar - but the L2D-CE is rated at 55 hours on 2x AA vs. 21 hours of the P1D on primary CR123A
Not fair, those were older gen Luxeon III lights - how about other Cree based lights?
One of the current brightest lights Fenix P1D-CE -
alkaline Turbo vs. Fenix P1D-CE primary CR123A High
perhaps not surprising - since both are on 3V -
BUT the P1D-CE has the advantage of Lithium technology which is capable of delivering sustained higher currents - alkalines are well known to droop.
So this is actually quite an impressive performance from mere 2x alkaline AA's.....
vs. Fenix P1D-CE both on primary Low
L2D-CE has a noticably lower low.....and is rated to run for 55 hours vs. 21 hours of the P1D-CE (which is brighter)
Of course the main advatage of the P1D-CE is its much smaller size - use of Lithium battery -
but the L2D-CE runs on common AA's - has a much easier UI (user interface) due to the (reverse) clicky switch - and can use the 1x AA L1D body when they become available with a slight decrease in brightness performance and about 1/2 the runtimes please see - Fenix L1D-CE Comparison Review.
For grins I wanted to see how the Cree XR-E in Fenix L1/2T (link) performed against the L2D-CE - since I originally speculated the Cree Mod in L1T/L2T was kind of like a preview for the L1D-CE and L2D-CE........ so was I right?
Turbo vs. Cree XR-E in Fenix L1/2T High - both on alkaline
similar perhaps the Cree Mod L2T may have a slightly more diffused beam since it is using a McR18 stippled reflector........
(so maybe I was right?
Low vs. Cree XR-E in Fenix L1/2T Low - both on alkaline
The Cree Mod L2T has a noticably brighter low - its estimated runtime based on the rated L2T low is about 22 hours vs. the rated 55 hours of the L2D-CE
is the Low of the Cree Mod L2T as bright as the Medium of the L2D-CE?
in a word - no........
Wait!........
There's more.....
How does the L2D-CE compare to the Fenix L1D-CE ?
vs. Fenix L1D-CE both on alkalines - Turbo -
Important Note: the positions are reversed - the L1D-CE is on the left and the L2D-CE on the right.....
L2D-CE is brighter...... but the L1D-CE uses only a single AA.
L2D-CE on 2x Lithium AA vs. Fenix L1D-CE on 3.7V Li-Ion Rechargeable 14500 - both on Turbo
L1D-CE using Li-Ion is just brighter than the L2D-CE on Lithium Primaries....
Current draw on NiMH and primary Lithium - Post #11
Part 2 - Fenix L2D-CE NiMH vs. Primary Lithium AA - Post #17
Part 3 - practical indoors Stairway beamshots - Post #21
ReFocussed beamshots comparison - Post #26
ReFocussed Stairway beamshot comparison - Post #29
Fenix L2D CE and L1D CE runtime graphs by Chevrofreak
Size -
Head -
Wait!........
There's more.....
