wintermute
- Joined
- Nov 16, 2004
- Messages
- 681
OK, so my new L2D CE w/OP reflector was bright...really bright. But I put a WC tint Q4 in it. Wow, is this thing bright. So I just decided to test this out a bit.
2 x Sanyo Eneloop batteries - 2.5V under load --- Pulling 1.6A from the batteries = 4.0W to the driver.
Assuming a 90% driver efficiency, that's 3.6W to the LED. Voltage at the LED is 3.7V...that means ~970mA to the emitter.
Edit (add): (Assuming a 85% efficiency, that's 3.4W to the LED which means ~920mA to the emitter)
Has anyone else tested the Fenix lights to see what they're drawing from the batteries and such?? Doesn't that seem quite a bit for a Fenix L2D CE?? I am going to compare it to a SSC P4 w/ VIP-750 and post beamshots in a couple of days. There's a good chance that the efficiency is less, but still - quite a bit to the emitter, right?
