BentHeadTX
My Fenix L2D Q5 has developed a problem that has me stumped
It will only come on in low mode, you can have it in "turbo" at it operates in the much dimmer low mode. Toggle the tail switch and it will strobe but only at low output. Loosen the head and it runs low, tap the switch and medium, high and SOS modes work but again only with a dim output.
I changed my Eneloops with my Turbo AA2 which runs very brightly and it stays low. Shorted the body with some wire and it still runs low. The tail switch is good as I swapped parts from my L1D RB100, tried the shorting wire trick and I still get low output.
Tried putting it in turbo mode and let it run for around 4 hours and it regulates only in that low mode. It acts like it is stuck in that mode but the "disco modes" work at the low output.
I have tried everything but it seems the head has a malfunction and stays a regulated low output. Figures, the light made it a year and now it becomes a long running emergency light?
Any ideas?
Any ideas?
