Once again, hot off the press, through the kind courtesy of 4sevens , is this Fenix LD10 single AA light based on the Cree Q5.
Commercial links removed - Empath
I actually got all the new LD and PD series from 4sevens - but since I have a preference for single AA lights - the LD10 gets the quick once over first.
But it should be noted as with the previous series the LD10 head is the same as the LD20 and PD20 - so if one gets the spare bodies for LD20 and PD20 - one in fact gets 3 lights in one - 1xAA, 2xAA and 1xCR123 - very, very versatile.
In fact the LD10 head does fit and work on the older "L" series bodies and the P2D body.
Size -
Head -
Comparison beamshots -
vs. L1D-Q5 both on Turbo and NiMH (Kodak Pre-Charged)
again my sample of one of the L1D-Q5 seems to show blue/violet - but in real-life it is more pink/violet. The new LD10 seems just a bit brighter - but it has a slightly narrower beam and this is probably within sample tolerances.
vs. L1D-RB100 (Rebel) both on Turbo and NiMH
the LD10 seems to just have it - but the RB100 tint and beam are just nicer - although the LD10 Q5 is pretty good already.
vs. NiteCore D10 (Q5) Max and NiMH
about par - my sample of one of the NiteCore D10 seems a bit of an over-achiever and it's rated at 130 torch lumens - so the LD10 is doing very well.....
Index to follow up parts -
Tint shift on low - Post #6
Comparisons using 3.7V rechargeable Li-Ion 14500 - Post #15
Comparison with another sample of the L1D-Q5 - Post #17
Standardized Stairway beamshot - Post #19
Size -
Head -
