I've been using the Fenix L2D Q5 as my primary bike like for a while now and I want to put a second one on there. I will most likely go with another Q5 but not sure of which one to get.
The reason why I like the Q5 in the Fenix PxD/LxD is that the hot spot is nice and wide and the spill is nice and bright. So my question is, are all the heads exactly the same? Can I expect the same wide hotspot and bright spill in a P2D Q5 and a L1D Q5. I assume that all the heads will be the same and have the same or similar beam pattern.
So should I just get another L2D or go for a P2D and swap the body tube with my L2D P4? I can't imagine why they would change the beam pattern for the P2D so if anyone has both could confirm that, I would be most grateful.
