45/70
I've never really timed how long it'll run. I use 650 mAh Powerizer unprotected 3 Volt cells. The few times I've run it till it dimmed down, I'd guess it was probably around 40-50 minutes. Again, this wasn't with a watch. Using unprotected cells, I try not to run them down to the drop off point, which is good advice for Li-Ions anyway.abvidledUK said:Thanks
What sort of RT do you get ?
Does it appear to follow a regulated output, ie quite constant for quite a while ? upto 120 mins RT
Or like the 3.6v RCR123's, high for a shorter period, then dips dramatically ? upto 60 mins RT
Or somewhere in between.
From CF's graphs above, I would expect somewhere in between.
As far as dimming, to my eyes, it seems like flat regulation till the end when there is an obvious drop off. A light meter may show differently.
Dave
