It is fairly simple to drill a new hole in the adjacent ridge.
i've broken 2 of them at the keyhole. Dont have pics or the lights anymore, but i drilled out the BACK of the tube, threaded a tiny eyebolt thru it and loctited it in with a Nylock nut, washers and loctite.
Bomber tough!
Maybe a modding service?i've broken 2 of them at the keyhole. Dont have pics or the lights anymore, but i drilled out the BACK of the tube, threaded a tiny eyebolt thru it and loctited it in with a Nylock nut, washers and loctite.
Bomber tough!
I never use fishing snap swivels directly in the keychain hole-- the thin gauge steel wire wears through the soft aluminum much quicker than split rings.
Did the poster say he used fishing snap swivels?
It is post #1 if you would like to double check.
