I sent the following email to [email protected] and got the response included farther below.
EMAIL TO FENIX
I understand that the P3D is designed for two 3.0-volt primary batteries and is not warranted to work with rechargeables.
Will typical 3.0 volt RCR123's and 3.6/3.7 volt protected RCR123's fit? Do you know the tube's inside diameter?
Will a typical (3.7v) R17670 battery fit? Will it operate normally? Normal operation means that I could use all the normal light-intensity options (low, medium, high, turbo) and operate the flashlight until the 17670 battery spends a normal cycle of energy.
What are the min./max. voltage thresholds of the regulator?
Can the IC handle up to 8.4v? Does the IC have low-voltage shut off?
What is the current draw in Turbo mode?
RESPONSE FROM FENIX
The tube's inside diameter is 16.8mm. And its voltage is from 6.0-8.4V, when the voltage is low, the light will warning.
Please help me interpret the response from Fenix. Would I be correct to believe that using two standard 3.6v RCR123's would work without harming the LED? How about other rechargeable options?
I understand that much of what could be said would be speculation until the P3D's ship around 4/20/07. However, Fenix did give some new data that is not posted by their distributors.
EMAIL TO FENIX
RESPONSE FROM FENIX
