This Fenix TK-45 is a Testing Samples that provided by Fenix for Review purpose and thank for Malaysia Fenix Disturbution in the time .
Notice Given By Fenixlight marketing department. :
Be attention: The test TK45 is testing sample, not mass sales product, so maybe here are some little defects on the falshlight. Pls be aware.
Here is the parcel that i received :
Nice packing here :
Guess what things is inside the Cases :
Waa! A New TK-45 Flashlight With a Manual instructions included , but too bad didn't have other accessories included like lanyard that listed on the Instruction manual and previous version, Fenix TK-40 with shoulder strap, two spare o-rings, and a rubber switch boot since this TK-45 is a TESTING SAMPLES .
What things writen on the TK-45 Instruction Manual ?? Here is it :
Page 1 :
Page 2 :
TK-45 appearance and design :
The 3 head of TK-45 look like machine gun .
There are two button switch ,one button used for on/off and another button is for mode settings
: Low , Medium , High Turbo
Other than Fenix TK-45 word printed , there is a two words printed which is " Testing Sample " .
But don't why this TK-45 din't have this logo printed ??
OR
This TK-45 is more cold so don't need this logo ??
Then if more cold , they should show this logo :
There will be a battery holder with gold plated on the electric conductor :
There also have gold plated on the electric conductor on the circuit board
On the head or top of the battery , the will be TK-45 word printed on the circuit board .
Clear plastic , u can see through the plastic the thread of the screw that to cover and tight head and end of the battery holder
The flashlight tube have two O-rings on each end to prevent water entering to the body of flashlight .
The lamp head with O-rings to prevent water entering inside and damage the CREE LED
But the CREE LED in this TK-45 TESTING REVIEW look like it is not using the Cree XP-G LED (R5) but using Cree XP-G R4 LED which is FENIX LD10 using . Here is the comparison of CREE LED between two flashlight which is FENIX TK-45 and FENIX LD10 .
Battery used for testing is :
Sanyo Eneloop Tones
Beamshot :
The Picture Will Coming Soon
Runtimes:
There will no comparison between because didn't have other high end flashlight .
Here is the picture that the Fenix TK-45 light up under negative effect :
FAQ :
What is the price for this unit of flashlight ?
The price is $152.95 according to the Fenix-Store , https://www.fenix-store.com/product_info.php?cPath=22&products_id=2341
Where to buy ?
Online shop like :
http://www.fenix-store.com
http://www.fenixtactical.com
Pros :
1) The TK-45 flashlight have 3 CREE LED and can provide 760 lumens.
2) It is the highest lumens on Fenix products lines .
3) AA battery more easily to get in the Market now .
4) Have a gold plated electric conductor on the battery holder and circuit board to prevent current loss on the resistant .
5) Value and worth to get it , the price is $152.95 compared with the price of previous version TK-40 which is $157.95 that only have 630 lumens .
6) It is waterproof and don't worry for any outdoor activities .
7) It also use a new CREE LED which is Cree XP-G LED (R5) with lifespan of 50,000 hours.
8) New electronic switches , right side switches to on/off and left side swiches to cycle the brightness of the flashlight and intelligent memory function for memorizes last primary output when activating the flashlight .
Cons :
1) The TK-45 battery holder is plastic and cannot fix the AA batteries very well so it is hard to install the battery.
2) Still using AA battery , should allows to uses more high end battery like lithium battery .
3) Use too much of battery to light up the flashlight , 8 of AA batteries and so it will be more heavy compared normal flashlight .
4) It not included other accessory like shoulder strap, two spare o-rings except for lanyard (listed on the manual instructions).
5) The is tube of the flashlight too big to insert the battery holder inside because it make a lots of noise when shaking or other action after u inserted or installed the battery holder with full filled AA batteries .
More imformation will be updated soon ...
Please rate it and give a comment about this FENIX TK-45 Flashlight .
