Hey,
I've been trying to determine how accurate the lumen ratings are for the listed values for Fenix lights. I've seen Chevrofreak's excellent runtime plots with approximate lumens but I guess I'm still a little confused.
A few years back, most of the calibrated lumen ratings were low. For example, my Surefire L4 was 65 lumens. Then it got bumped to a 100 lumen rating by Surefire. I'm not sure how my HDS EDC was measured, though at 60 lumens it does indeed appear to be not as bright as the L4. My Fenix L0D CE seems a little dimmer than its rating but that might be due to the throw/reflector characteristics. (no, I'm not using alkalines)
So if the L4 is 100 lumens, how does that compare to Fenix light rated at 100 lumens? The Fenix L1D CE Q5 is listed at 120 lumens for 1.5 hours-- is that actually more output than a Surefire L4 for the same amount of time, off a single AA NiMH?? Or how about a Fenix T1's 210 lumens of output... does it really throw about 2x as many photons as the L4?
Has my Surefire L4 become so obsolete already? Or are the integrating spheres just calibrated differently or something?
The same question applies to my HDS EDC. Is it obsolete, or were they just conservative measuring its output?
I just think something seems amiss, because my Surefire X300 also uses a Cree LED and it is a 2x 123A light rated at 110 lumens with a 1.5 hour runtime or so before it drops off. How can the Fenix T1 produce double the lumen rating, with the same runtime, with what I assume is the same LED?
