dom
Hi Guys
Myself,Ktronik and Darell have all played a part in getting this light off the ground.
"min-T" stands for mini triple -which is the type of optic used in these lightweight,versatile bike lights.
The optic is either a 10deg spot or 25deg flood at the moment.
Up to 1A current can be pumped into the LEDs -which will in turn throw out many Lumens (we'll say over 400 so no-one will argue
These initial min-T's will be using the Seoul LED , SVO warm white emitter from PhotonFanatic and bFlex driver.
Will have user adjustable voltage warning LED showing through the back cover and also user adjustable thermal protection for those really slow hot days.
The bFlex provides multi levels of light with user adjustable current and modes and also strobe mode and you need at least a 14.8V battery to run them properly.
After many months of work and testing we have some min-T bike lights on the go and would like to offer either DIY kits or built-up complete heads.
There are 15 on the go and this lot will be engraved on the back with your name or whatever (within the confines of the rear cover).
The picture above is showing the versatility of the mounts -which can swivel any which way and be affixed to virtually any part of your bike or helmet.
Also shown is the remote switch which is offered separate and also a Plasti-dipped and velcroed battery -which also can be placed anywhere easily on your bike.
This is an "expression of interest" thread and you are under no obligation to purchase if you have second thoughts -as Ktronik,Darell or I will gladly keep them ALL to ourselves:nana:
All right -to the nitty-gritty.
Shell Kit: Incudes : bare head.optic of your choice,driver holder and switch holder,switch,full mount kit. US$180 & $10 P&H
Complete Head Kit: Comes with everything except battery or remote switch ,programmed to your spec. All needed connectors provided (battery,charging,remote) connectors are Deans and mini-Deans.
US$350 & $10 P&H.
You would have to specify how you want the input wiring sorted.
Remote min-T Switch: US $10 if bought with either kit.
OK - i think that is all for the moment
Here is a link to the thread from when we started the min-T
http://candlepowerforums.com/vb/showthread.php?t=172053
PS -the pics above are only prototypes -will provide pics of finished version this weekend -only a few slight changes:devil:
OK Folks Time to confirm you interest and what you want exactly.Please include what you would like written on the back cover -or PM/email that info.
Will update what you want next to your name and also shipped/paid status as we go on.
Spare Part List:
o-rings FRONT OR REAR $0.50 each
Large Deans plugs (pair) Power $3.00
Small Deans plugs (pair) Remote $2.00
10 or 25deg optic $6.00
350mm length 4.5mm mount rubber $2.00
350mm length 4.0mm remote rubber $2.00
Remote switch assembled (no shrinkwrap or plug) $20.00
Swivel mount complete
(includes ball and M4 SS grubscrew) $30.00
Extension Cord $10.00
Here is an example of what i cobbled together for my wiring.
My setup is on the bar with the battery mounted to the stem -so only short wiring is needed.
Ktronik will be doing all the electronic/wiring work
Your needs may differ.You just need to state them.
For eg. If you intend to use as helmet mounted you will need an extension cord -unless you want a long wire hardwired.You also may want the remote wire hardwired.
That is if you have an aversion to plugs
Had this sitting in a bucket of water for 3hrs with no leaks.
Should you need an extension cord Ktronik will make these to suit as he has more experience with the use of them.
Black sealing Sikaflex will be used on all joints -not the white shown on the build-up pix.
Polarity for the (large power) Deans plugs
If you are looking for batteries -there are a couple of ways to go.
There is a good range in the US
Lithium-ion are lightweight -these use 18650 type LG batteries.
This is a 2+ hr runtime battery pack (at 1A) and 1.5A charger
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2003
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2488
If you had varied ride times you could use 2 of these packs -1 pack for shorter rides -2 pack with "Y" parallel cable for 4+ hr rides.
Or you could just get a 14.8V 4.8Ah (or more) and same charger.
Browse the site for different combos and bargains.
This place also has similar type batteries and chargers
http://www.all-battery.com/index.asp?PageAction=VIEWCATS&Category=290
These are just examples.
Should you order a built-up head -these have to be prepaid and they shall be completed within 2 weeks of Ktronik receiving them to work his magic and send them to you.
Machining on most, if not all will be complete this weekend -so Ktronik will be getting them Tuesday next week or close.
Should you only want the shell kit -these can be paid on the day they are sent -not before please.
Feel free to ask any questions
PM or email me for payment details please.
PP cash or PP CC add 3% -other payment options could be worked out.
All payments will stay in account till notice has been received of delivery of goods.
Interested Parties List:
1. TranquilityBase - Full Kit + Name + Wired as per pic PAID SHIPPED RECEIVED
2. PhotonFanatic - Full Kit 25deg + Name + 18" Power Extension + Optic + Wired as per pic PAID SHIPPED RECEIVED
3. Hendrik -Full Kit + Remote + Optic + 2 Small Power Deans + 120cm Remote & Power Ext Small Deans + o-rings (1 each) + 4.5mm Rubber + Name + Wired Small Deans PAID SHIPPED RECEIVED
4. Royce -Shell Kit - 2 Remotes + 3 off each o'rings + 3 Large Deans + 3 Small Remote Deans + 1 Each Rubbers + 2 Power Ext 60cm & 50cm+Name PAID SHIPPED RECEIVED
5. Royce -Shell Kit PAID SHIPPED RECEIVED
6. RGB_LED -Full Kit 25deg + Remote 11" + 2' Ext + Large Deans + 4.0 & 4.5mm Rubber + 2 X 14.8V2.4Ah PlastDipped and Velcroed Batts + Charger 1.5A + Parallel "Y" Cable PAID SHIPPED RECEIVED
7. HJW -Shell Kit + 2 Remote 20" wire+ Name PAID SHIPPED RECEIVED
8. HJW -Shell Kit + 2 Remote 10" wire+ Name PAID SHIPPED RECEIVED
9. MattP - Shell Kit + Remote + Optic + Name PAID SHIPPED RECEIVED
10. Amorphous -Full Kit + Remote + 2ft Power Ext + 2 types 0-ring + Extra Mount Kit + Optic + Wired as per pic + Name PAID SHIPPED
11. Chelly -Full kit + Remote + 4 Deans(2 sets each type) +5 o-rings + Optic + Name + Wired as per pic PAID SHIPPED
12. Hendo -Full Kit 25deg + Remote + 3 o-rings + 4 Deans(2 sets each type) + 4.0 & 4.5mm Rubber + Wired as per instruction PAID SHIPPED RECEIVED
13. Andy -Full Kit + Remote + Name + Wired as per pic PAID SHIPPED
14. Gunnar -Full Kit 25deg + Remote + 2 front o-rings 1 rear + 2 Big Deans 1 type each Small Deans + 4.0 & 4.5mm Rubber + 10deg optic +110cm Power Ext + Some Wire and Shrinkwrap + Name PAID SHIPPED RECEIVED
15. Jesse(WhiteLight) Full Kit 25deg + Remote + Optic + Wired as per pic + Name PAID SHIPPED
Back Up List -
1.Darell - the works
SHIPPED RECEIVED
2. Boco
3. TOMTEC
4. Karl
5. merkaba
Thanks for looking
Cheers
Dom
US$350 & $10 P&H.
Spare Part List:
Back Up List -
2. Boco
3. TOMTEC
4. Karl
5. merkaba
Thanks for looking
Cheers
Dom
