Fixing a light on the side of a construction helmet
ECL
I want to put a quark AA2, that will potentially be upgraded to 18650, on an construction helmet I use for SAR. I already tryed the niteIze headband but it's too small and the shape of the helmet makes Peltz like elastic bands slips upward.
There is also mandatory reflective rim on the lower edge of the helmet that requires the solution to be removable.
I'm tapping on the CPF members wizdom for ideas.
Hey, I've been tinkering with the same idea. Not for SAR, just the rotating shift, industrial work site my wife and I have to deal with. Some discussion of this topic in this thread.
Our work hardhats are run-of-the-mill Bullard's. They perch above your noggin, hanging off the inner suspension straps. This is typical of all or most industrial hardhats. The "perching" method gives airspace between the helmet and your skull, which is good from a protection standpoint. But it also means that any weight attached to the hardhat shell which is not balanced causes the hardhat to list.
If your SAR helmet is more like a Petzl rock climber's shell, or a bicycle helmet, you'll be less affected by imbalance issues.
Does your hardhat have the slots above the left and right ears? Petzl (EDIT: Pelican, not Petzl, sorry) makes a couple of clamps that plug into the standard hardhat slots. I think they're kind of dopey-looking, but they might work for you. Their clamps aren't generic; some are distinctly oval-shaped to accomodate their flashlights although I imagine similar lights like some of the Streamlights might fit.
As described in the above thread, I disassembled a clip-on faceshield and kept the little plastic pivot points that clip into our hardhats. Using a little strip of stainless sheet metal I created a bracket for a small AA flashlight, but the imbalance created by this small flashlight and bracket was intolerable. Looks like I'll have to make more brackets, and either load up both sides of the hardhat or none at all.
Bullard sells goggle clips for their hardhats. The goggle clips are nothing more than a bit of hard plastic shaped into a clip with some strong adhesive on the back. You stick two or three of these onto your hardhat, and the clips should hold onto just about any headlight that uses a headband. Seems to me the Bullard clips (or something similar) might be the simplest solution to your situation.
Yeah, I forgot to mention velcro. About half the guys at work have Princeton Tec EOS headlamps strapped onto their hardhats. Most of them just use duct tape, or a couple of zip-ties threaded thru the previously mentioned slots above the ears, or chicago-hose pins, or what have you.
Some folks are using the adhesive-backed velcro tape that comes in two parts - the "hook" side and the "loop" side.
What we discovered out at work was that the fabric used in the Princeton Tec EOS headbands gripped strongly to the hook side of the velcro. So all you need to do is stick a few pieces of the hook velcro to the hardhat. The loop side isn't used. I'm not absolutely sure this is the case with all headlamp bands, but it's certainly worth checking out.
I have a feeling that you might find a Quark aa2 too heavy. You may want to think about saving for a Princeton Tec Apex or some other fairly bright headlamp. Or get a Fenix headband, detach the part of the the headband that goes over the top of the head, and either keep the battery storage full or get another flashlight to keep the weight balanced. We've got two of the Fenix headbands. The Quarks fit into the clamps.
ECL, this is something I've been trying to figure out as well... from what I have found, there are potentially a few solutions that I like:
1. Helm-a-clip
- Mounts the light above the brim so it may depend on how much of a brim your construction helmet has.
2. Blackjack holder / Firestore link
- Mounts the light below the brim but primarily made for firefighter style helmets which have wider brims. I like this solution as I understand that, despite the light only being mounted on one side, it apparently doesn't overweight the helmet to one side. Check out the video on their website.
3. Underwater Kinetics
- UK appear to have several different clips, depending on whether it's a fire or construction helmet, including their "Universal Clip".
Again, I have only looked into these solutions as well so I have not yet tested any of the holders. If any other CPF'ers have tested holders, please let us know as I'd be curious to hear how effective they are and what sort of issues appear for helmet-mounted clips.
The helm-a-clips look very similar if not identical to the Pelican - not Petzl as stated earlier, sorry about that - hardhat clips. Pelican makes several different styles of clips, some for wide firefighter brims, some for round lights, some for oval lights.
Those Blackjacks look very cool! Appears to me they would work best on the wide-brimmed fire fighter's hats rather than a standard industrial hardhat, which has a much less pronounced brim.
Here's a link to the Bullard adhesive goggle clips
The Underwater Kinetics devices look very interesting too!
If someone were to mold something that looked like the lower half of the UK device, mated to a flashlight receiver that functioned as well as the Fenix headband units, they'd have a winner on their hands.
The problem with all those clip is that there is no details about maximum and minimum siex flash light that can fit into them. Therefore if you don't own the light it was design to hold you might end up with a clip too small or too big.
On the othe hand, the Petzl elastic retainer in combination with a fenix head band might be decent fix. Pu a light on the left and the right and you also take care of the weight imbalance.
a regular headlamp will work much better than the fenix headband and handheld lights.
