The 50mw DX green I have does work well, and I like it, except for the switch.
I've got 2 problems- one, sometimes the laser turns on weakly WITHOUT pressing the switch. I killed the batt once because of that. It's kinda scary to have the laser on without the switch on and all but it IS faint. I'm not sure what's conducting here but it sure ain't right.
Second, you touch that switch much at all when it's on and it tends to make the beam drop out and flicker.
OK, so, bad switch. I even have a bunch of flashlight clicky switches I got earlier and I think it may be the same type... maybe. Any advice on replacing this? The brass housing has no opening big enough to get the switch out! It looks like they put the switch in sideways, turned it flat, then rammed it back up against the brass collar. Which explains why the button presser is so loose in back, it had to have enough free room to rotate the switch around I guess.
