kosPap
Hi all!
I had some spare time this morning so I set up this Flashlight Photography Made Easy Tutorial
Part 1
This is about MY version of setting up the photographing space...
Here is a sketch of my setup which is easy, fast and quite good.
(on the left the setup I use, one the right the optimum kind)
What it actually is: My book case has a cupboard (?). I use this as a platform...on the overhead bookself I have jammed a white plastic food serving tray under the books...Presto!
The idea is to cope with a single flash unit on/of the camera. Then you bounce the flash on the overhead white reflector and that disperses and smoothes the light, but also removes the nasty shadows at the background.
The improved version is better because it sends more light in front of the subject than my current setup does...It is all about controlling the shadow intensity. (I like it though, ‘cos it helps with the three dimensional appearance)
Qaution: Do not use a cloth for the white surface, the cloth’s weave will show nasty...Just plain printer paper from A3 to A1 size...
NOTE: For those that do not have an external flash unit, I suggest making a kind of upwards and forward deflector using cardboard, aluminum foil as lining and tape. I have done it ages ago for another purpose, but I have no time doing it again...Maybe latter some day....
Add-On: There are more issues to it... Aperture/Depth of field control, Aperture/Flash Intensity Control, Flash Intensity Control Only, Frame over/underexposure. For owners of DSLRs these are easy.
There is a real danger that you may get dark/underexposed pics...This is because you are using a dark object on a white background. Too much light is reflected back before the dark flashlight is lighted correctly. (Ok Ok I know about slow-curtain sync, but this is beyond this post)
Sorry for the rest, the users of P&S and compact cameras, it cannot be done properly any other way. You’re only option is to use Exposure Compensation if your camera has it...
Part 2 – Photoshoping the pics
This is a quick and easy guide to Photoshoping...For people that do not use photoshop there is a simpler yet powerful FREE alternative: Irfanview
NOTICE: Proper workflow practices dictate that you work on COPIES of your photographs. There is no going back with the following simple methods.
Great Big Tip before we start. One of the easiest ways to learn photoshop is by reading the pop-up labels when you point the cursor to a button. Then you wonder “so what does this thing do?” and you learn by trying.
Step 1 – Color Correction
Photoshop has a good utility on the levels window...The eyedroppers convert the pixel you click to black, grey and white respectively...
That means that when your color or lightness is off you just have to point them to the parts that are real life white and real life black...Then the bias will be removed and colors most of the times will be restored to their real life values. Then you can refine adjustemts using the middle slider of the levels graph
Step 2 – Desaturating the Shadows (with a revolutionary selection tutorial)
This is a nice feature for your photos. We use the desaturate command on a selection that is made easy, fast, and reliable. (With more hidden features for advanced users).
The idea is that photoshop allows you to make a selection my making a mask on the said region. And you only have to paint on the region when in mask mode. (Follow the arrows – double clicking on the mask icon that dialog box opens and gives you masking options). You can choose the brush size and style clicking at the button that is poointed by the arrow at upper left. And if you want ot dix a mistake just use white paint or the eraser tool.
After you’re done you exit the mask mode and presto you have a selection ready!
TIP: If you want to use any tool in Photoshop in a straight line you Shift+Click in the beginning and again Shift+click on the end of the line, Presto!
Then you apply the desaturation command. Ready!
Step 3 – Cropping and Resizing
Cropping is when you remove unwanted material from a photo. And you got to resize to CPF standards (800 pixels at the widest)...So here we go,
This is the simplest of the all, but with a BIG negative effect.
We use the Crop Tool. We enterthe desired image size in Pixels in the boxes and we either leave the resolution box empty or we input a value of 96. Then we fit the cropping window at the image area that interests us, and we press Enter.
This method forces the image to these dimensions, but it is very hard in shrinking it. It just throws away resolution but in an inefficient manner, creating jagged artifacts. (Hell, it shows in several of these pics too). And thinks get worst when we start with a many Mpixels image. (I purposefully shoot CPF pics in 2MP)
(Resolution and image size when we edit photos are co-depended in an inverse way. When we increase one we decrease the other. Also the pics you see here are a 640x320=0.23Mp equivalents. And under normal conditions it is hard to imagine any CPF grade pic going over 0.43Mp). So plan accordingly!
What we can do is resize our picture before we crop it...We upsize it if it is too small and downsize it if it is too big. We do that gradually 10-20 percent of the time and apply sharpening as needed. Here how it is done:
NOTE: The issue of cropping and resizing is far more complicated if you want to get GOOD results...The only way to guide you within this tutorial is too suggest using high resolution and then using the “Save for Web” command as seen in these pics:
ETA: As stated above, depending from the method used there are cases that a higher initiall resolution is needed. When you are going to use the save for web feature you might as well use a high resolution image...
Step 4 –Resizing Only
For standalone pics outside Photoshop there is a simple way to do it.
Go to msn.com and search for the Windows Powertoys. One of them is called Image Resizer. After you install it, it puts a line in the right click pop-up.
Clicking on it brings up this dialog box...Very Easy
Part 1
