traderdell
- Joined
- Jun 17, 2009
- Messages
- 51
I also posted this on the EDC Forum.
Thanks in advance!
Gregg
Flashlight Recommendation Checklist
1) Short Essay Question: What do you intend to use this light for?
Mostly for walking the dog. We live in a very rural area, no street lights of any stripe. We walk in the yard, down a lane way to the edge of our woods.
I thought I had decided on a Dereelight Javelin and still think it would be a good light for me but given what I will be using it for I'm wondering if it has a usable flood.
2) What Region/Country/State will the light be purchased in?
[√ ] I will be mail-ordering or buying online, so this doesn't matter.
3) Price Range: An easy question, but you may change your mind after answering the rest!
[ ] $1-15
[ ] $15-30
[ ] $40-60
[√ ] $80-$120
[ ] I have no limit!
4) Format:
PART A
[ √] I want a flashlight.
[ ] I want a headlamp.
[ ] I want a lantern.
[ ] I want a portable spotlight.
PART B
Length:
[ ] 1-2 inches. (Keychain sized)
[ ] 2-4 inches. (Pocket carry)
[ √] 4-9 inches. (Holster carry)
PART C
Width:
[ ] I prefer a long narrow light.
[ ] I prefer a short wide light.
[√ ] Doesn't matter.
PART D
5) What kind of "bulb".
[ √] LED - more rugged, unlikely to burn out in your lifetime, less accurate color rendition, in general less output but more efficient (longer runtimes)
[ ] Incandescent - can be very bright, more accurate color rendition, burn out or can be damaged more easily, shorter runtimes, very noticeable dimming as batteries deplete
[ ] HID - like new car headlights in color, very, very bright, can be had in lights as small as a Mag 2 D cell but generally larger spotlight sized lights, no dimming turns off when battery depletes
[ ] Don't care, just want the best fit for my needs.
6) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
[ ] I want common Alkaline batteries. (AA, AAA, C, D)
[ ] I want lithium batteries. (coin cells, CR123, AAA, AA...)
[ √] I want a rechargeable system. (an investment, but best for everyday use)
7) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
[ ] I want to read a map, find a light switch/keyhole, or get around the house at w/o disturbing anyone. (5-10 lumens)
[ ] I want to walk around a generally paved area. (15-20 lumens)
[√ ] I want to walk unpaved trails. (40 lumens)
[ ] I want to do Caving or Search & Rescue operations. (60+ lumens)
[ ] I want to light an entire campground or dazzle an intruder. (100+ lumens)
8) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an “X” on the line below. Sometimes a flood is better particularly closer up or indoors. You won't have to "sweep" the light back and forth to see what you need to see. You can also just set it down pointing the general direction rather having to point it right at that which you are working.
Throw (distance)----------------------|----------------------Flood/close-up
9) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries. Understand that runtime is a function of brightness and capacity of your batteries. If you want 6 hours you'll either have big batteries or dimmer light, they haven't made a setup yet that lights up like the sun, runs all night, and fits in your watch pocket.
[ ] 20 min. (I want the brightest light for brief periods)
[√ ] 60-240 min. (1-2 hours)
[ ] 240-360 min. (4-6 hours)
[ ] 360+ min. (More than 6 hours)
10) Durability: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
[ ] Not Important (A “night-stand” light.)
[ ] Slightly Important (Walks around the neighborhood.)
[ √] Very Important (Camping, Backpacking, Car Glove-box.)
[ ] Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
11) Switch Type:
[ √] I don't care.
[ ] sliding switch (Stays on until slid back.)
[ ] clickie switch. (Stays on until pressed again.)
[ ] momentary switch. (Only stays on while held down.)
[ ] rotating switch
12) Switch Location:
[√ ] I don't care.
[ ] I want a push or sliding switch on the body near the head.
[ ] I want a push switch on the back end of the body.
[ ] I want a rotating head switch.
[ ] I want a rotating end-cap switch.
[ ] I want a remote control.
13) Operational Modes: Check all that apply.
[ ] A simple on-off is fine for me.
[ √] I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
[ ] I want multiple light levels. (some lights have 5-16 light levels.)
[ ] I want a strobe mode. (blinks to show location.)
[ ] I want a tactical strobe. (Flashes rapidly to disorient an opponent.)
[ ] I want S.O.S. flashing
14) Is it important whether the body is metal or plastic/composite? In this case "plastic" and it's variants does not mean "cheap" or poorly made. In many applications a plastic bodied light is preferable, hard use and water resistance comes to mind; think caving or lights that get dropped or abused.
[ ] I don't care.
[ √] I want a metal-bodied light.
[ ] I want a plastic/composite light.
Thanks in advance!
Gregg
[ ] $1-15
[ ] $15-30
[ ] $40-60
[√ ] $80-$120
4) Format:
PART A
PART B
Length:
PART C
Width:
PART D
11) Switch Type:
[ √] I don't care.
[ ] rotating switch
[√ ] I don't care.
[ ] I don't care.
