liteman437
- Joined
- Sep 22, 2010
- Messages
- 2
Hello, I am in need of some help.
I own an EagleTac T100C2 MKII and have ran into a big problem. I unscrewed the head because I wanted to oil the threads since it sounded a tiny bit "grindy". Well, I did that, lightly oiled the threads, and screwed it back together... and now it will no longer change to high mode. It's supposed to be on normal mode until you completely twist it tight, which is when it turns to high mode. Now it permanently stays in normal mode. :(
There is a metal ring with a little gap on the outside of it that does move around, and I'm thinking it maybe might have moved a bit? I'm not sure, but I do not know what to do to fix it. Does anyone here know what could be causing this? Should I keep moving the ring slightly and screwing it back in? :shrug:
I have been attempting just that for the past 20 minutes, and have had no luck in getting it to work right again. I would really appreciate some help from you flashlight gurus, to help me fix my stupid mistake. I should've never even touched the head :ohgeez:
