I've had this light for a while. This is the newer Duel-fuel 1500lm version.
I have noticed straight out of the box, that when running it with 18650s 3,7V batteries, on the lower output levels while on the Intellibeam setting, there are a few points in which the light ever so slightly flickers, just for a short moment.
Some people might not notice this at all, and in actual use, or when lighting things from a medium to far distance, this is not noticeable. I find it very strange nonetheless. It does not increase/decrease brightness while it flickers (in a sort of stepped brightness-adjust way), it simply flickers while not altering the brightness of the light. This always happens at the exact same point, and no matter how slowly or quickly the brightness increases/decreases.
When using 2x CR123 3V Batteries, with a combined voltage of 6, this phenomenon does not occur at all.
Now my question is; if anyone here has (or had) this light, can you confirm this behavior in your example? Do I simply have a lemon?
Is this the fault of the batteries? The voltage? The light itself?
I have been testing with 3 different 18650 batteries (the original SF one, and 2x Keeppower 3500mAh ones), and even with multiple Keeppower 16650s (even though turbo does not work with those due to too high drain, the Intellibeam mode however does. Same phenomenon).
Does anyone have any insight on this? Reasons for it? Ways to fix it?
This does not kill the light for me, it has however always been somewhat of an annoyance to me.
