Is it normal when my QIII is cold (night in the car at -5C°) the luxeon flickers and if i hold it for +-30sec in my hand i just works fine?
Is it the battery (original 123A) who can not handle the amps as it is cold, or is it the circuitboard, or the luxeon itself?
I have almost the same problem with my TM301X5 : i have replaced the lux5 with a luxIII (with resistor so it runs on 2pcs 123A at +-900mA).Works very well and more trow as the QIII. Only; when temperature is -5C° and i swiths it on: the luxeon glows (like a 5mm led!), and after some time, or when i swiths a couple of times on/off, then suddenly i works fine???
Thanks Marc
Thanks Marc
